Necrofire
- Nov 1, 2007
- 585 (0.09/day)
System Name | Chuck |
Processor | Core i5-2500k @ 4.5Ghz |
Motherboard | msi P67A-C43 |
Cooling | hyper 212, 2 120mm fans |
Memory | 8GB DDR3 1600MHz |
Video Card(s) | XFX 6870 |
Storage | 60GB sata3 sandforce ssd, 1TB samsung hdd |
Display(s) | Yamakazi Catleap |
Case | Possibly Antec, not sure |
Audio Device(s) | Onboard |
Power Supply | Rosewill 600W |
I want to do the 7-volt trick for a noisy fan in my case. The problem I have is that my brother said that anything that would use the same 5 or 12 volt line, there would be feedback of some sort and it might damage either the power supply or whatever was on those lines. Is this true? Is there something bad about getting 7 volts from the 12 and 5?
He does have a bachelors in electrical engineering, btw, so if don't have any background using electricity or have done this mod yourself for more than a couple of months, I don't want to hear it.
EDIT: I'm so stupid, I had just assumed that my 12 volt fan could not start at 5 volts. Well, I'm thinking of reusing my 12 volt tornado at 5 volts, since I just tried it and it's really quiet.
I can't believe I never thought of just trying it.
