- Jan 1, 2021
- 38 (0.02/day)
- France
System Name | Enter name here |
Processor | Ryzen 7 3700x w/ PBO |
Motherboard | Asus Prime B550 Plus |
Cooling | Bequiet dark rock 4 |
Memory | 2x16 Crucial Ballistix 3200 Micron E-die@3800Mhz 1,41 18-16-20-18-38-58 |
Video Card(s) | MSI RX 6800 Trio X |
Storage | Samsung 980 1Tb + Crucial mx500 250go + Toshiba HDDs |
Display(s) | Dell s2721ds |
Case | MSI Mag Forge 100R |
Power Supply | Coolermaster MWE bronze 650w |
Benchmark Scores | CInebench R20: 5085 |
Hi everyone and happy new year !
I admit it, i've been a long time lurker here since 2016, thanks to Der8auer and Buildzoid mostly.
I seek today your advices for overclocking further my old fx 8350.
Heres my system specs:
CPU:Fx 8350 (with Noctua NT-H1 paste)
MB: MSI 990FXA GD-80 (8+2 true phases)
RAM: Kingston DDR3 4x4Go 1600Mhz 1,65v @1,506 Mhz (1T 9 10 10 27)
Cooling: Hyper 212 with two HighRPM Silverstone FM122 fans on push & pull
PSU: Cheap 550w bronze (OEM from HEC)
VGA : Asus strix 980 (-72mv ,88% Powerlimit, stock clocks)
And heres my CPU clocks and voltages entered in my BIOS:
CPU Clock: 4407MHz-4633MHz
Multiplier: x19,5-20,5
FSB (equivalent to Bclk on intel): 226
CPU-NB clock (northbridge): 2486 Mhz
CPU Vcore 1.42v
CPU-NB : 1,36v (this helps when increasing FSB)
NB voltage: 1,27v
APM : off (I paid for all the phases, i want them all!
C6 & C1e States: off
HPC mode: on
HT-link: 2712MHz
As you might know this motherboard doesn't have any LLC presets so i get a 0.04v Vdroop on vcore on loads.
I have Cool&Quiet and turbo enabled because i want dynamic clocks (it gets hot during summer).
Through some software, I make them not go below 2,3Ghz though.
I have tried setting software P-states but the voltages gets very wonky and i'm not sure about that.
Temperature wise i get stable 53°c under prime95 (@60% fixed fan speed)
In most games i play, i get cpu bound so i want to OC a bit further and i know for fact that increasing the FSB (and northbridge) helps a lot in singlethreaded performance.
Also don't say "upgrade already!" because if i could, i would lol. (plus FX overclock is fun)
So i'd like to push FSB to 240 or more if i can, i have not tried 231+ yet.
If you guys happen to overclock fx, help would be very much appreciated
Edit: My cinebench r15 scores are around 725cb at the moment (stock was 642cb).
I forgot to mention when i say dynamic clock, all the cores runs at turbo (x20,5) speed under load with no throttle. (without any vcore bump from x19,5 though)
So just assume i run x20,5 multiplier.
And I do run this system daily.
Thanks.
CPU Vcore 1.42v
NB voltage: 1,27v
HPC mode: on
HT-link: 2712MHz
Thanks.
