A Little Confused About Undervolting
24 (0.01/day)
System Name The Mean Machine
Processor Intel Core i9-11900K Desktop Processor 8 Cores up to 5.3 GHz Unlocked LGA1200 TDP 125 Watts
Motherboard ASUS - ROG STRIX Z590-E GAMING (Socket LGA1200) USB 3.1 Gen 1 Intel Motherboard with LED Lighting
Cooling Thermaltake UX200 ARGB Lighting 120mm Hydraulic Bearing CPU Cooler
Memory CORSAIR Vengeance LPX 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600)
Video Card(s) ASUS AMD Radeon RX 5500XT Overclocked O8G GDDR6 Dual Fan EVO Edition HDMI DisplayPort Gaming Graphic
Storage Sabrent 1TB Rocket NVMe PCIe M.2 2280 Internal SSD High Performance Solid State Drive (2)
Display(s) Lenovo C27-20 27-Inch WLED Monitor, FHD, IPS, FreeSync, 75Hz, 4ms, HDMI, VGA, and a ASUS VE278H 27"
Case Phanteks Enthoo Pro Full Tower Chassis with Window Cases PH-ES614P_BK,Black
Power Supply CORSAIR HX Series, HX850, 850 Watt, 80+ Platinum Certified, Fully Modular Power Supply
Mouse Logitech M720 Triathalon Multi-Device Wireless Mouse – Easily Move Text, Images and Files Between 3
Okay, I hope the title is slightly better, but here goes the question. I have to say I thank Throttlestop for what it does. Without it I couldn't get my temps a little lower than they are. But is it better to do the same thing inside the BIOS than through software?
Do we have a place for undervolting as we do Overvolt?
you might be better off watching youtube videos on the matter, just youtube "how to undervolt your cpu" and watch a few videos. jayz2cents did one recently i know. bios can do it on some boards, yeah. i don't think it matters either way, but some you tube videos might have better insight for you
I can do it on my board, but I have to move a jumper on it first. I'm not sure what the name of the jumper is, but it actually deals with overclocking. I don't want to overclock, just under volt my CPU.
Thanks
Well there's definitely more parameters that could be adjusted from the BIOS though most wouldn't need to be changed
Using a software is easier for an average user
In the BIOS undervolting and overvolting is the same thing: Adjusting the voltage
