asmanthebell
- Apr 1, 2010
- 10 (0.00/day)
Specs:
Intel Extreme Quad Core2 QX9650(4.5GHz-1600MHzFSB)
ASUS ROG Maximus II Gene(Manual OC Mode)
4x 2GB Kingston HyperX DDR2(1300MHz5-5-5-15T2.2V)
2x ASUS EAH5770 CuCore(1024MHzVGA-1500MHzMEM CFM)
Lite-on BDROM (iHOS104-32 3)
LG Super Multi 22x DVD-+RW Light-scribe
HP Personal Media Drive Bay (250GB USB2.0 7200RPM)
Creative Titanium PCI-E X-FI (7.1)
OCZ 500W Super Quiet Power Supply
2x Seagate 500GB 3GBs HDD C32MB 7200RPM
Seagate Barracuda 1.5TB 3GBs HDD C32MB 7200RPM
Trust USB2.0 WiFi BGN+ (Internal)
Trust USB2.0 Bluetooth 2.1+
ASUS 26" VK266 LCD Monitor
ROCCAT VALO Keyboard
Microsoft Explorer Mouse 3.0
Microsoft XBOX 360 Controller for Windows.
APC Back-UPS ES 700
Bose 7.1 Surround System
Logitech 2.1 Sound System(Traveling)
Windows 7 64bit Ultimate-Bitlocked
Extended Kingston Special Edition Ram Heat-sinks
Kingston HyperX RAM Cooling Block Fans 2500RPM MBC
2x ASUS ROG Temperature Sensors (RAM&PWRSupply)
Cooler Master Freezer Pro 7 Rev.2
Mods:
Custom Built Clear Acrylic Case Full ATX
4x Blue LED 2500RPM 12V Fans
50x Cable Mini Cable Tidies
5x Alaska Cable Velcro Tidies
2x USB2.0 Expansion Cables
HDAudio Front Panel Connector
My first custom built PC designed and and hand made by laser and milling machines designed on ATX form factor for power PC installation in mind.
As you can see by my photo dated the 10/03/2010 is the first photo i took in the dark this was just a test run too make sure it all worked after i put it all together.
Photos dated 01/04/2010 are the latest update and have more to follow once amazon deliver the other graphics card and new power supply XD.
05/04/2010 - Today after adding two IDE DVD rewriter i found acrylics nemesis --->DUST! It sticks everywhere i might rethink this idea and come up with a non stick clear coating. Any ideas would be appreciated.
I think next i am going to incorporate some glowing fluorescent UV paint across some cables and use the clear acrylic to transmit around the case to enable the glow factor.
A 7.6 Windows 7 64Bit Ultimate Intel 775 Socket Rated PC.
Cost so far £2741.
Specs:
APC Back-UPS ES 700
Mods:
Cost so far £2741.
