Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to TechPowerUp Forums, Guest! Please check out our forum guidelines for info related to our community.
The forums have been upgraded with support for dark mode. By default it will follow the setting on your system/browser. You may override it by scrolling to the end of the page and clicking the gears icon.
i got an abit ag8 motherboard (intel grantsdale). it comes without spread spectrum option in CMOS bios setting. if i have to do some setting on it (i.e. enable/disable), what should i do? for example. flash in the mod BIOS to the eprom? thanks.
If it is enabled and there's no option to disable it with any bios there's available, I would take a modding tools and BIOS file I'd like to use and look is it possibly coded into BIOS. If you can find it there and its hided, just change it so you can see it or possibly disable whole setting for good and flash the modded bios.
