Abnormally high CPU temperature in BIOS! Should I ignore?
9,019 (1.37/day)
System Name Black Panther
Processor i9 9900k
Motherboard Gigabyte Z390 AORUS PRO Wifi 1.0
Cooling NZXT Kraken X72 360mm
Memory 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz
Video Card(s) Palit RTX2080 Ti Dual 11GB DDR6
Storage Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm
Display(s) 32'' Gigabyte G32QC 2560x1440 165Hz
Case NZXT H710i Black
Audio Device(s) Razer Electra V2 & Z5500 Speakers
Power Supply Seasonic Focus GX-850 Gold 80+
Mouse Some Corsair lost the box forgot the model
Keyboard Motospeed
Admittedly this is the first time I checked what CPU temperature was displayed on the bios screen since I got the E8400 and oc'd it to 4.2Ghz.
And... well I'll let the pictures speak for themselves -
Using Realtemp I idle at ~31 degrees and at 100% load never go above 58 degrees. Coretemp used to read both temperatures like 5 degrees higher.
And here's a picture of the bios CPU temperature... :twitch:
When I had the E4300 the problem was that the bios always showed a very low temperature. Overclocked at 3Ghz that processor used to idle at 39 degrees on coretemp, while reading 20 degrees in the bios which wasn't possible so ignored the bios reading.
Now to install the E8400 I had to flash to another bios (due to 65nm/45nm difference in processor)... so did something go wrong, should I dismantle heatsink asap, or should I just disregard the bios temperature reading? :confused:
I rarely get an accurate CPU temp off of an Asus board. You could try reflashing the bios again though I doubt it will help.. but you never know. I just like to use Everest/RealTemp/CoreTemp and whatever reads highest is my "safety range". The key really is just not to feed a 45nm chip too many volts. :)
Use latest RealTemp and load it with prim95 Small FTTs. Tell me distance to TJMax in load please.
That happens with a lot of BIOSes. The CPU is "too fast" to execute/run the BIOS setup software, it is stressed to "slow down", enough to let the BIOS setup utility software run well. This is similar to certain software / emulators slowing down the CPU to let legacy apps run. It's not a cause for concern.
That's a beta... :ohwell:
Yeah, use it, it doesn't bite. :D
It's some steps forward from 2.70, and not only for E8400. You have a CPU Cooldown test for spotting a stuck sensor, adjusted TJMax, nVidia card temperature and other improvements.
