- Dec 5, 2012
- 533 (0.12/day)
Processor | i7 6900k @ 4.3GHZ |
Motherboard | MSI X99A Godlike Gaming Carbon |
Cooling | CPU/GPU loop with 480mm and 360mm radiators |
Memory | 32GB Corsair Dominator 3000MHz C15 |
Video Card(s) | 2x EVGA 1080 SC ACX @ 1830/1330 |
Storage | Samsung 950 Pro M.2 512GB, WD 2TB Black HDD |
Case | Corsair 900D |
Power Supply | EVGA 850W Gold 80 plus PSU |
Software | Windows 10 Pro |
Hey guys,
So I only finished putting my PC together a few days ago, but have been having some issues with it since.
The first thing is that after logging in, for around 20 seconds or so there is a considerable delay in response time between my keyboard and the PC; I'll hit the windows key and the start menu will pop up half a second later and the same goes for regular typing. There however is no lag when opening programs or with the cursor.
The second issue is that the benchmark scores I've been getting are abnormally low, I attached a couple of images:
For Time Spy, I got 13561 graphics score (test 1=85.10 FPS, test 2= 80.48 FPS) and 9872 in CPU
________________________________________________________________________________________
My Graphics cards, which are EVGA GTX 1080 SC ACX 3.0 cards, both on water (as is the CPU). Using EVGA precision X, they seem to be stable at 1830/1330MHz with 120% power consumption. They idle at around 30 degrees celsius and during heaven averaged at around 50-55, peaking at 65. In valley however they generally stay below 40. In time spy, I wasn't able to check because EVGA precision X prevented me from running the benchmark for whatever reason. During Heaven, the VRAM usage was around 1.5GB, and around 2.5GB during valley if I remember correctly.
If it matters, I'm using an EVGA Pro SLI bridge with 2 slot spacing and the cards in lanes 1 and 4. I am not sure why, but the card in lane 4 was automatically made the primary card. (Or at least I think it is; the monitors are plugged into the card in lane 1, which shows up as card (2) in the Nvidia control panel).
SLI is enabled with the setting "Maximise 3D performance" and the PhysX processing is set to auto. I have 3 monitors, all are 1080p.
My apologies for the essay, I am just trying to provide as much information as possible as I haven't a clue what is causing the issues.
Any suggestions are welcome,
Thanks
EDIT: I forgot to add, my heaven score isn't too far off what it should be; maybe around a thousand point? The valley score however is way below what it should be and closer to what you'd get with a single 1070.
EDIT 2: I disabled SLI and ran valley and heaven again. With a single 1080 I score 2864 in heaven, and 5373 in valley (Effectively the same in valley with as with sli on, but around 60% as high as in heaven with SLI on). I don't understand what would cause that.
I removed the CPU part as the issue is resolved; it turned out to be EVGA precision XOC causing the startup lag.
From what I've seen online, people with single 1080's are getting around 3000-3200, while I'm only scoring 2850. I cannot find any for dual 1080's, but 4600 seems to be even less than what you'd score with two 980 TI's.
Thanks
