Activating TPM on X570-F
Status
Not open for further replies.
Normanne
6 (0.40/day)
I just want to go to Windows 11 but my PC doesn't recognize/ find TPM.
You might have to update your bios if the revision is old enough. There was a time were TPM was not there.
The thing is the setting is there. Or is that unimportant? I did activate the setting but it still doesn't work. Still update?
First start with mention which mainboard you have and BIOS Version.....
When in the BIOS go to Advanced -> Advanced\AMD fTPM configuration -> Make sure to set it from the drop down menu to "Enable Firmware TPM" -> Go to Save changes and Exit -> Reboot.
Windows should now see TPM as ready to use.
Good luck...
Good luck.
It's already set to Firmware TPM. Still doesn't sees it as ready to use :(
Please mark as solved.
Status
