AHCI vs RAID
52 (0.01/day)
System Name Home PC
Processor Intel Core i5 2500
Motherboard Asus P8H77-V LE
Cooling Cooler Master
Memory Kingston 4+4 GB DDR3 1300MHz
Video Card(s) Sapphire HD7870 Ghz Edition
Storage Seagate 1TB+Kingston V300 120Gb SSD
Display(s) I-O DATA 1080p Casual LED
Case CM Elite 370
Audio Device(s) Builtin
Power Supply Enemax 600 watt
Software Windows 7 64-bit & Linux mint
I have just bought a Asus P8H77 VLE SATA 6gbps in my previous MOBO Asus P8H61 MLX there were just two option under SATA control IDE and AHCI but in New Mobo there is one option RAID i have a SSD Kingston V300 120 GB which is SATA 6gbps and a 1 tb Seagate HDD dont know if is its SATA 2 or SATA 3 HDD. My Question is whar should i select here for Better Performance?AHCI or RAID?
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
Even if I never intend to set up a RAID, I still use it. The drivers tend to be better and you can set up a RAID in the future without any changes to the OS.
AHCI is available option for legacy support (really old IDE drives).
52 (0.01/day)
System Name Home PC
Case CM Elite 370
You mean I should Select RAID?in Reality i select RAID but when PC boot there a windows Comes up and and in Green FONT i can saw NO RAID DRIVE..
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Can you take a picture of this? You can upload it to www.techpowerup.org
The RAID software should say it is a "non-RAID disk" and that's normal. You shouldn't have to go into the RAID setup at all because you're not using a RAID.
Note: Changing this setting after an operating system is installed is inadvisable.
Solaris17
Super Dainty Moderator
27,610 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on chitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Wikipedia said:
Many SATA controllers offer selectable modes of operation: legacy Parallel ATA emulation, standard AHCI mode, or vendor-specific RAID (which generally enables AHCI in order to take advantage of its capabilities).
Solaris17
27,610 (3.84/day)
Alabama
VR HMD Quest 3
in systems that usually only offer enhanced AHCI or RAID configurations. Just because AHCI (As well as RAID) support IDE drives does not necessarily mean that is what they are for. and since RAID also supports IDE drives. your persistence to use it over AHCI
Still makes no sense.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
The bold section is the "IDE" mode on most motherboards, not AHCI. AHCI's purpose is entirely for SATA operation. It is what is responsible for the extra features of SATA such as hot swapping and NCQ as well as TRIM support.
RAID mode on the other hand activates the chipsets firmware RAID. If you aren't actually going to set up a RAID array there isn't much point in enabling RAID mode. In fact it can actually be limiting in some ways, such as TRIM not working properly on SSDs(big issue with AMD, newer Intel chipsets now allow trim through RAID and Intel actually managed this by making their firmware RAID somewhat AHCI compatible).
Answer to OP's Question:
If you don't plan setup RAID, leave it set to AHCI. The reason it pops up in green saying No RAID Drives is exactly that, you don't have any RAID arrays in the system and no drives in the system capable of making a RAID array. You need at least two, somewhat similar drives in the system to make a RAID array. A 128GB SSD and a 1TB HDD are not similar enough to create a RAID array. So Intel's firmware RAID is smart enough to not even let you try and just gives you the message.
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
AHCI, RAID is AHCI but requires more than one drive
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
You may be right but not for the reason given. When RAID is enabled, the controller gets a boot device in the BIOS but if you don't go into the RAID config and set a boot device, the BIOS doesn't know what to run when it is told to boot. This can lead to the error. The solution would be to go into the RAID config and set the appropriate drive as bootable then set the BIOS to boot to the RAID controller.
Alternatively, the drives may show up individually in the BIOS if they aren't explicitly added to a RAID. Make sure you select the appropriate drive from the RAID list if that is the case.
MxPhenom 216
ASIC Engineer
13,172 (2.46/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27ACDNG 360Hz QD-OLED | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" 1440 IPS 1440p
Mouse Razer Viper v3 Pro
Simple answer:
Set to AHCI if you aren't planning to run a RAID array. Set to RAID mode if you are running a RAID array (RAID 0,1,5,10)
You are making it more difficult than it needs to be. Not to mentioned trying to argue over correct information....
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
I would just set it to AHCI. That's the most simple way to go. Intel RAID software for drive management still works in AHCI mode so this really is a non-issue. RAID should be used if you plan on using RAID, it's really that simple.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
With Intel RAID, at least on all the recent Chipsets I've used(P55, P67, Z68, Z87, Z97), everything connected to the Intel RAID is visible in the BIOS. Multiple RAID arrays appear in the BIOS. So if you create Array_00, Array_01, and Array_02 and have a single lone drive connected all 4 devices will show up in the BIOS just like they are standard hard drives. You pick the boot device in the standard BIOS just like picking a boot drive normally.
What you are describing is usually the process when you are using a 3rd party controller.
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
True, however the controller itself will still the the RAID controller driver as opposed to the AHCI driver. The biggest benefit in my personal opinion is that if you don't have chipset drivers installed and it's set to AHCI, it's almost certain to pick up the generic Microsoft AHCI drivers where with RAID, it very well might not detect the chipset RAID driver OOTB.
For simplicity sake, I still think using AHCI is a better idea if you don't need RAID. I see no benefit of running RAID without having a RAID array.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
IDE is the old compatible mode, AHCI is the newer SATA2/SSD compatible mode, and RAID is designed for multiple drives working together.
Depending on your controller, you MAY lose some features running the RAID mode, so i highly recommend AHCI.
For example, on some chipsets running RAID meant TRIM would stop working, which negatively affected SSD performance.
AHCI is the 'safe' and reliable option if you don't plan to run RAID any time soon.
Deleted member 6693
Yes - but RAID is a great alternative if you are running with "old fashion harddrives".... RAID 0 can really speed things up,
(on the cost of secureness in a drive fault situation)
Mindweaver
Moderato®™
8,440 (1.44/day)
Charleston, SC
System Name Tower of Power / Delliverance
Processor i7 14700K / i9-14900K
Motherboard ASUS ROG Strix Z790-A Gaming WiFi II / Z690
Cooling CM MasterLiquid ML360 Mirror ARGB Close-Loop AIO / Air
Memory CORSAIR - VENGEANCE RGB 32GB (2x16GB) DDR5 7200MHz / DDR5 2x 16gb
Video Card(s) ASUS TUF Gaming GeForce RTX 4070 Ti / GeForce RTX 4080
Storage 4x Samsung 980 Pro 1TB M.2, 2x Crucial 1TB SSD / NVM3 PC801 SK hynix 1TB
Display(s) Samsung 32" Odyssy G5 Gaming 144hz 1440p, 2x LG HDR 32" 60hz 4k / 2x LG HDR 32" 60hz 4k
Case Phantek "400A" / Dell XPS 8960
Audio Device(s) Realtek ALC4080 / Sound Blaster X1
Power Supply Corsair RM Series RM750 / 750w
Mouse Razer Deathadder V3 Hyperspeed Wireless / Glorious Gaming Model O 2 Wireless
Keyboard Glorious GMMK with box-white switches / Keychron K6 pro with blue swithes
VR HMD Quest 3 (512gb) + Rift S + HTC Vive + DK1
Software Windows 11 Pro x64 / Windows 11 Pro x64
Benchmark Scores Yes
Always use RAID or AHCI on any SATA drives. Remember, using IDE compatibility mode limits the drive to UDMA 133 speeds 133 MB/s which is close to SATA1 1.5 Gbit/s - 150 MB/s. Which is why most people don't bother with AHCI or RAID for the small gain, but I would.. ;)
Hard Drive speeds
  1. IDE Ultra ATA/33 = .3Gbit/s - 33 MB/s
  2. IDE Ultra ATA/66 = .6Gbit/s - 66 MB/s
  3. IDE Ultra ATA/100 = 1Gbit/s - 100 MB/s
  4. IDE Ultra ATA/133 = 1.3Gbit/s - 133 MB/s
  5. SATA1 = 1.5 Gbit/s - 150 MB/s
  6. SATA2 = 3 Gbit/s - 300 MB/s
  7. SATA 3 = 6 Gbit/s - 600 MB/s
EDIT: Forgot to add that for a single drive I would use AHCI driver over a RAID drive for no other reason than to boot up quicker. Enabling RAID will check your RAID array on startup and give you a chance to change or create a RAID array.
52 (0.01/day)
System Name Home PC
Case CM Elite 370
I have selected Raid and installed windows 7.but Now i m getting 80% performance of my SSD and getting this on HD sentinel " the trim feature of the ssd is supported but disabled " like in picture bellow
http://i.imgur.com/9GThiiQ.png
what should i do to get 100% performance?
MxPhenom 216
ASIC Engineer
13,172 (2.46/day)
Loveland, CO
Why did you choose RAID? Doesn't look like you are running a RAID array.
and TRIM is probably disabled because I do not think your chipset supports TRIM with RAID setting.
52 (0.01/day)
System Name Home PC
Case CM Elite 370
I selected this Before posting this thread i have Asus p8H77 V LE i don't know if its supports trim with Raid or not..but need help to get 100% performance.
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
You gain bandwidth at the expense of IOPS. Seek latency goes up when you use RAID as all drives needs to get to the same sector and could take different amounts of time to get there. I strongly believe if you need performance SSD is the way to go. If you need mass storage, you're most likely going to want to keep your stuff safe and will tend to read data more than write it, in which case RAID-5 is superior across the board as you gain redundancy and read performance at the expense of disk space (you get N - 1 drives worth of space) and write performance (as parity blocks must be calculated and written).
However I've now been side-tracked... Just go with AHCI. You can always switch to RAID down the road if you even end up caring about such things.
Side note: TRIM being issued to SSDs with the RAID driver depends on the version of RST (or RSTe in my case) as a newer (and unsupported version for X79) was required before I gained TRIM though my RAID. Another way to keep this simple is... using AHCI. :)
19,379 (3.46/day)
AHCI. While using RAID wont hurt anything, it wont help anything either unless you are actually going to use RAID... but as Aquinas said you can just switch to it without any issues (outside of building your array of course). It was also mentioned that using RAID without an array can increase boot times as it looks for an array.
TRIM has worked in RAID for quite a while now, again as Aquinas said, so long as you have the latest driver (though I recall it being in the chipset/INF/RAID ROM and not the rapid storage drivers??). Update em both. :)
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Where are you getting the 80% number from?
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
For my case, the latest X79 chipset RAID driver stopped at version 3.6.x.x. TRIM in RAID was added to RSTe in 3.7.0.0 and the latest version for C600 series chipsets is 2.8.0.x last time I checked which was a year ago. I forced installation of the newer RSTe driver to get it to work. It's also why my RAID driver says C600+/C220+ instead of X79. I had to get creative. :p
52 (0.01/day)
System Name Home PC
Case CM Elite 370
Can i run existing windows 7 with AHCI sata setting?i have installed windows with Raid when i boot windows changing from raid to ahci it goes to blue screen error for eye blink time and restart again.is there any method?
