Aida64 does not show gpu fan rpm
18,584 (2.63/day)
System Name AlderLake
The gpu fan shows 0rpm but it is spinning.
Does MSI Afterburner or GPUz have a fan rpm reading?
would there be no sensor for it? Or is it broken?
Oh, you are on a laptop, that is why. There is likely only one blower fan that blows air onto a heatsink that cools both the CPU and GPU. The 2300rpm fan that is showing in AIDA is your cooling fan. So you are fine. You dont have a dedicated fan for the GPU.
It is because you are on laptop, on my lenovo y510p it is same...
I do have 2 dedicated fans I have an Asus G750JX.
Try to put the GPU to work(like futmark or game) and see the sensors, I bet will show you...
This is the backside of my laptop, the air outlet on the left is for GPU the one on the right for CPU
I did but in aida64 is stays 0% and GPU z does not show it at all
Even if you re open aida after you start furmark?
Yes I tried, it stays at 0%, maybe there is no sensor for the GPU fan speed as GPUz does not show it at all.
Or the sensor may be broken somehow? The CPU and GPU fan are both spinning and it's a brandnew laptop
Try Open hardware monitor or MSI afterburner it might work and there both free.
I see 44C on your GPU, it is a good temp, I think, from my try, that gpuz and aida don't read those sensors...
I think so...
Open hardware did not show any fan speed.
There may not be a sensor in my laptop for the GPU fan
Yes it runs 44~45 idle and 70 max with gaming.
It is a good temp...
I have 755m single, in idle I have ~44C on 25C of room, I see my temps are almost same as yours(maybe a litle up at me at cpu(50C with mess, browser, firewall, av)), I did not try in game to see the temp, I just game light (Mass Effect 3 mp, Torchlight 2, sacred 2,...)...I changed the termal paste at mine(put MX-4), I think I gained 1-2C, so I have warranty on him, I just use him, no care much of temps now...
