[FS][US] Alphacool RTX 3080/3090 GPU waterblock
212 (0.04/day)
System Name Insurrection
Processor Ryzen 7 9800X3D
Motherboard ASUS TUF Gaming X670E Plus WiFi
Memory 64GB DDR5 6000Mhz G.Skill Trident Z5
Video Card(s) MSI Gaming Trio RTX 4090
Storage Samsing 980 Pro 1TB NVMe
Display(s) Samsung G9 Neo
Case Phanteks P400A
Power Supply MSI MPG A1000G
Mouse Razer Naga Epic
Keyboard Crosair K95 Platinum RGB
VR HMD META Quest 3
Software Windows 11 Pro 64bit
Greetings folks today, I'm selling some watercooling gear that I no longer need. These have only ever been run with distilled water and a few drops of PT nuke. No colored dyes or any other fluid types.
Up first we have the EK Supremacy EVO CPU block. This has been a great CPU block and has all the mountings, jetplate adapters and inserts for virtually any modern CPU. It has cooled everything from a 8700K to my current 12700K. I have the LGA 1700 mounting kit for it for all current gen Intel CPUs as well. I ran my CPU daily at 5Ghz P core and 4Ghz E core for daily use and this kept temps in the 60s (of course your radiator and fans will affect this) but I've never had a problem with it and it's just performed great from day one.
This is the model here:
https://www.ekwb.com/shop/ek-supremacy-evo
Next up is my Alphacool Eisblock Aurora GPX-N block for the FTW3 variants of EVGA RTX3080, 3080 Ti and RTX 3090 cards. It's a full cover block with full ARGB support that you can control from your motherboard. It comes with a black aluminum backplate for a really nice look in the case. I've run this on my a RTX 3080 FTW3 and my RTX 3080 TI FTW3. Temps stay in the mid 50s load (again depending on your radiator and fan arrangement) block is in great shape, no scratches or scuffs on the acrylic and the RGB works great too. You will need some 1mm thermals pads for installation of the block and some 2mm pads for the backplate, they are cheap and easy to find but I linked a few down below:
1mm thermal pad
https://www.amazon.com/ARCTIC-TP-2-APT2560-Performance-Installation/dp/B00UYTTDO6/ref=sxin_17_ac_d_mf_brs?ac_md=1-0-QVJDVElD-ac_d_mf_brs_brs&content-id=amzn1.sym.57f74923-af1a-4e1a-b97b-9c2e72717055:amzn1.sym.57f74923-af1a-4e1a-b97b-9c2e72717055&crid=2BYE8WKCV460&cv_ct_cx=1mm+thermal+pad&keywords=1mm+thermal+pad&pd_rd_i=B00UYTTDO6&pd_rd_r=152b6ea9-0ce8-417f-b596-db4adcd62196&pd_rd_w=2gqq3&pd_rd_wg=46LLC&pf_rd_p=57f74923-af1a-4e1a-b97b-9c2e72717055&pf_rd_r=BP4ZE219M4TXC771QTCP&psc=1&qid=1657574515&sprefix=1mm++ther,aps,85&sr=1-1-dd96d2aa-78c0-4648-bd3e-11643d087866
2mm thermal pad
https://www.amazon.com/100x100x2mm-Conductivity-efficient-Dissipation-Performance/dp/B08GSCJ5W1/ref=sr_1_14?crid=YY7WYRPTOXM&keywords=2mm+thermal+pad&qid=1657574616&s=electronics&sprefix=2mm+thermal+pad,electronics,65&sr=1-14
This is the exact block here so you can read more if you want:
https://modmymods.com/alphacool-eis...3080-3090-ftw3-with-backplate-11943-6802.html
For brevity these are the cards listed as compatible:
RTX 3080 TI
EVGA GeForce RTX 3080 Ti FTW3 Ultra, 12GB GDDR6XRTX 3080
RTX 3080
EVGA GeForce RTX 3080 FTW3 Ultra Gaming, 10GB GDDR6X, HDMI, 3x DP (10G-P5-3897-KR)
EVGA GeForce RTX 3080 FTW3 Gaming, 10GB GDDR6X, HDMI, 3x DP (10G-P5-3895-KR)
RTX 3090
EVGA GeForce RTX 3090 FTW3 Ultra Gaming, 24GB GDDR6X, HDMI, 3x DP (24G-P5-3987-KR)
EVGA GeForce RTX 3090 FTW3 Gaming, 24GB GDDR6X, HDMI, 3x DP (24G-P5-3985-KR)
CPU Block = sold
GPU block = $85 shipped in conUS
I accept PayPal
HEAT is 185 - 0
CPU block is sold
