AMD gpu info on regedit
3,352 (0.60/day)
System Name Dark Stealth
Processor Ryzen 5 5600x
Motherboard Gigabyte B450M Gaming rev 1.0
Cooling Snowman, arctic p12 x2 fans
Memory 16x2 DDR4 Corsair Dominator Pro
Video Card(s) 3080 10gb
Storage 2TB NVME PCIE 4.0 Crucial P3 Plus, 1TB Crucial MX500 SSD, 4TB WD RED HDD
Display(s) HP Omen 34c (34" monitor 3440x1440 165Hz VA panel)
Case Zalman S2
Power Supply Corsair 750TX
Mouse Logitech pro superlight, mx mouse s3, Razer Basiliskx with battery
Keyboard Custom mechanical keyboard tm680
Benchmark Scores 70-80 fps 3440x1440 on cyberpunk 2077 max settings
I wanted to know how to find the amd gpu on regedit,
since it seems impossible with all the folders it has,
even after searching and which key is the right one?
What exactly are you looking for in the registry?
when you see the info in dxdiag, it shows only 6700 series
I have to find the info from the regedit, without any other program used,
to find which model of the 6700 is.
In my case it's 6770HD
but i need to find it, in all computers, not just mine because i know it from gpu-z
or better saying, where is the key in regedit, of the graphic card models?
GPU-z reports from the driver. It's the driver saying 6700 series.
You may be able to get that information through the WMI interface, or directly from the drivers, but I don't know if that information is stored in the registry in that manner. If it is, it's not a reliable place to find the information as the registry can contain a whole lot of information that is not relevant if it's not removed when an application or driver is removed from the system.
WMI should give you the same results "Series" and not pin point card model. I was thinking of a way the other day... But it would take alot of time, is read the "Device Id". Perfect database would be the "VGA Database".
So your code would be more like
'Get DeviceID, in your case would be "1002 68BA".. or in my case "1002 6738" (6870)
'Check through your database for match ID
'Return Model Name
Just a thought tho.. hope it helps
Yeah, you can check device ID.
Or specifications. HD 6770, for example, has 800 SP while HD 6750 has 720.
