"AMD Only" DDR2 from China for Use in Intel System?
438 (0.10/day)
Midlands, UK
System Name Electra III
Processor AMD Ryzen 5 3600 @ 4.40 GHz (1.3 V)
Motherboard ASUS PRIME X570-PRO with BIOS 5003
Cooling Cooler Master Hyper 212 EVO V1 + 4× ARCTIC P12 PWM
Memory 32 GiB Kingston FURY Renegade RGB (DDR4-3600 16-20-20-39)
Video Card(s) PowerColor Fighter RX 6700 XT with Adrenalin 24.7.1
Storage 1 TiB Samsung 970 EVO Plus + 4 TB WD Red Pro
Display(s) Dell G3223Q + Samsung U28R550Q + HP 22w
Case Fractal Design Focus G (Black)
Audio Device(s) Realtek HD Audio S1220A
Power Supply EVGA SuperNOVA G3 750 W
Mouse Logitech G502 X Lightspeed + Logitech MX Master 2S
Keyboard MSI VIGOR GK71 SONIC Blue
Software Windows 10 22H2 Pro x64
Benchmark Scores CPU-Z = 542/4,479 — R15 = 212/1,741 — R20 = 510/3,980 — PM 10 = 2,784/19,911 — GB 5 = 1,316/7,564
Has anyone had any luck with buying so-called "AMD only" DDR2 from China for use in an Intel system?
I can't find any DDR2 that is advertised compatible with Intel at all, so this appears to be the only option.
Ideally looking for 4 × 4 GiB DDR2-800. Basically nonexistent otherwise.
The board is an ASUS P5Q PRO.
85 (0.04/day)
Alps (Bozen,Italia)
System Name Generic
Processor Ryzen7-9700x
Motherboard x670-p
Cooling Noctua
Memory 32GB DDR5-6400
Video Card(s) rx7600
Storage NVME 990Pro,980,Renegade
Display(s) Eizo, , NEC
Case FractalDesign
Software Linux,Windows,MacOS
intel Ram DDR2 very expensive, so i would say, no , not compatible.
(please prove wrong cause i am still interested in a 2x4GB buy of DDR2 for old Intel System)
stinger608
11,250 (1.87/day)
Wyoming
System Name 2023 Ryzenfall
Processor AMD Ryzen 5800X
Cooling SilverStone AH240 AIO
Case Corsair Air 540
Audio Device(s) On board
Oh hell, I've run all kinds of different DDR2 in the P5Q that I have, without issues.
I'd say, if it's cheap enough, go for it.
1,208 (0.27/day)
Denmark
Processor R9 5950x/i5 6400
Video Card(s) 7900XTX/6900XT
Case Custom builds
Audio Device(s) -
Could be a problem if dimms are dualsided when using all slots but havent used my Asus PQ5´s for a long time
248 (0.05/day)
It might only work with AMD memory controller. I have in my notes this now ancient blurb quoted from OCZ - which yea was for promoting some sticks WAY back but the important part is the address lines:
With 11 column address bit support by the AM2 memory controller, the number of addresses in each row or page can be as high as 2048 individual entries for a page size of 16kbit. Unlike modules based on standard 10-bit column address chips with an ?8k? page size, the new Titanium AM2 Special modules take advantage of the AM2 controller?s feature set and provide a single rank solution with 2GB density using ?16k? pages. This allows the controller to stay ?in page? twice as long compared to standard memory architectures, thereby achieving unparalleled performance.
578 (0.32/day)
System Name Mini efficient rig.
Processor R9 3900, @4ghz -0.05v offset. 110W peak.
Motherboard Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked.
Cooling some server blower @1500rpm
Memory 2x16GB oem Samsung D-Die. 3200MHz
Video Card(s) RX 6600 Pulse w/conductonaut @65C hotspot
Storage 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds
Display(s) Samsung C24RG50FQI
Case Jonsbo C2 (almost itx sized)
Audio Device(s) integrated Realtek crap
Power Supply Seasonic SSR-750FX
Keyboard Redragon K539 brown switches
Software Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched).
Benchmark Scores Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts.
problem is that intel ram controllers wont properly work with high density sticks (4gb per stick). On the other side the amd cpus had their ram controllers tweaked for ddr2 & ddr3 (for example Phenom II X6 supports both ddr2 and ddr3), so these cheap "amd only" ddr2 sticks are primarily designed for those users who decided to put a II X6 (or a II X4 but that one is kinda irrelevant in 2022) on a ddr2 mobo and want to put usable amounts of ram into it (16gb in 4x4gb config for example).
As for any normal desktop intel motherboard (lets say P35 and lower), you are limited to 2gb per stick (4x2gb is ur max amount in that case). With 4gb sticks these mobos just wont post. For later P45 mobos it may be different tho, as those came with revised chipset and may actually run 4gb ddr2 sticks.
5,482 (3.66/day)
Colorado, U.S.A.
Software Windows 11 Home
I believe single Rank DDR3 is AMD only, so I assume the same is true of DDR2
  • P5Q-PRO-QVL.pdf
438 (0.10/day)
Midlands, UK
I suppose I should preface all of this by saying that the system isn't intended to be a daily machine. I'm wanting to grab some independent data from the LGA775 platform with the 20 CPUs I have for a project I'm working on. I have an AM4 system for daily use.
The P5Q PRO is a P45 board. There aren't too many stories on the 'net about posting with 16 GiB, but there are at least a handful. Of course, people aren't very specific enough on the modules and configurations used, so it's nigh on impossible to use them for reference.
I may instead opt to grab a DDR3 board since second-hand DDR2 sells for kidneys these days.
stinger608
11,250 (1.87/day)
Wyoming
5,482 (3.66/day)
Colorado, U.S.A.
I would sell mine, but those DDR2 machines I have are still being used.
1,457 (0.34/day)
Australia
Makes you wonder why Intel have the p45 based boards as having support for 16GB total eh? There's obviously got to be a way for 4GB DDR2 DIMMs to work on these boards.
Testing a 1st gen dual rank DDR3 system right now with AM3 socket board, after multiple tests already can confirm all is well, at least with 800 series chipsets.
1,349 (0.21/day)
Milwaukee, Wisconsin, USA
Processor i7-3770K
Motherboard Biostar Hi-Fi Z77
Cooling Swiftech H20 (w/Custom External Rad Enclosure)
Memory 16GB DDR3-2400Mhz
Video Card(s) Alienware GTX 1070
Storage 1TB Samsung 850 EVO
Display(s) 32" LG 1440p
Case Cooler Master 690 (w/Mods)
Audio Device(s) Creative X-Fi Titanium
Power Supply Corsair 750-TX
Mouse Logitech G5
Keyboard G. Skill Mechanical
Software Windows 10 (X64)
I remember looking into this years ago, when all of those eBay listings had warnings for Intel users, that basically said don't even think about trying it and wasting our time and money. After researching it for a while and seeing things similar to what's been said in this thread, I decided I wouldn't bother.
1,457 (0.34/day)
Australia
Sounds like a marketing campaign to get end users buying up 2Gb modules instead & like I posted above, why on earth would Intel design P45 boards to support 16GB total ram with 4 slots on ATX boards then?
5,482 (3.66/day)
Colorado, U.S.A.
I have a Q45 chipset PC and it can't handle single rank 4GB DIMMS
438 (0.10/day)
Midlands, UK
That is okay, thank you. :)
I agree. For what it's worth, there are ASUS and Gigabyte boards based on the P45 chipset which support 16 GiB of DDR3 as well, when Intel's official documentation states 8 GiB DDR3 or 16 GiB DDR2. And then the P5Q PRO supports 1,600 MT/s FSB natively, which again isn't officially a thing from Intel.
Grand Theft Auto V appears to stutter quite badly with 8 GiB, despite the minimum recommending only 4 GiB. This is with a Core2 Quad Q9505, RX 460, and the game installed on a Crucial MX500. I expected it to be passable, but it doesn't mirror what I see on YouTube. There are YouTube videos with a worse GPU and the next Quad down giving better frame rates. All with the same amount of RAM.
I'm starting to lean in that direction as well. Not only is it costly, but for it to ship from China, most likely chosen at random, and then have the hassle of shipping it back if it arrives faulty/dead... I don't know if I'd want the hassle versus just buying a DDR3 board.
In hindsight, I should have looked into this prior to picking this board, but it's not the end of the world. I knew SODIMM DDR2 was expensive as I was looking for a 4 GiB module for my laptop, but I thought perhaps the situation for desktop might have been a little better. 1 GiB and 2 GiB modules are cheap as chips.
That is good to know. Thank you Shrek.
Ruru
S.T.A.R.S.
13,779 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
Really???? Well crap, I should sell a bunch of the DDR2 that I have. :p
Let's be millionaires, I have also hella lot of DDR2 as well. :D
5,482 (3.66/day)
Colorado, U.S.A.
On ebay DDR2 2GB is just over $4 each
I'd say that was reasonable.
Ruru
S.T.A.R.S.
13,779 (3.05/day)
Jyväskylä, Finland
Yeah not bad. And IMO 8GB is fine for those platforms.
44,274 (6.80/day)
Go by the qvl of Asus support page.
We just recently dealt with this in another thread. AMD only is guaranteed to work in AMD but a major crapshoot on intel.
1,457 (0.34/day)
Australia
Do you know what OS & version of it they are running it on in the video?, also what particular drivers they use?. All those details matter when comparing like this.
631 (0.54/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
The only way to be certain is to try. You will likely need to run slower timings than they are rated for, if they are recognised by the motherboard at all.
1,457 (0.34/day)
Australia
P5Q pro supports 16GB of DDR2, memory controller is in the P45 chipset. Go to page 9 of the motherboard manual, download from here.
The evidence of its support is clearly indicated in the motherboard manual.
I have the same board, but have never tried it with full 16GB of DDR2 as yet.
438 (0.10/day)
Midlands, UK
Of course, but not many channels disclose this information.
So far, I've found:
  • Core2 Quad Q9550
  • Windows 10 Pro
  • 6 GiB DDR3 instead of 8 GiB DDR2
  • GDDR5 version of the GT 1030
  • Core2 Quad Q6600 and Q8400
  • Windows 10 Home
  • 4 GiB DDR2
  • GTX 950
No texture popping issues whatsoever.
I'm using the latest stable driver for both my RX 460 and RX 570, which is 22.5.1, but I also tried an older one (21.5.1) which was installed courtesy of Windows Update when I finished setting up Windows 10 21H2 on the machine. I replaced the driver using DDU, and the game is installed on a Crucial MX500, and not a hard drive like in some of these videos.
The issue wasn't whether it supported it, but rather the type of modules that it supports. The QVL list of course won't be exhaustive and there are only a few 4 GiB modules referenced in it that can be used for all four slots:
  • Samsung M378T5263AZ3-CF7 (chip: K4T2G084QA-HCF7);
  • Qimonda HYS64T 512020EU-2.5-A (chip: HYB18T2G800AF-2.5);
  • Aeneon AXT960UD20-25D (chip: ?).
4 GiB modules seem quite expensive these days, and so I was asking about all this so-called "AMD only" memory that you see on the likes of eBay and AliExpress (because it's basically all there is), and wondering whether it truly was incompatible with Intel. They don't claim why it's "AMD only," but a little digging online seems to suggest that Intel chipsets don't enjoy the higher density modules, suggesting that these might be specifically for AM2 processors.
2,944 (0.65/day)
Fort Worth, TX
System Name LGA775 | BoX-Server
Processor Xeon E5450 OC3.6GHZ from 3GHZ | i3 3.4GHZ
Motherboard ASUS PQ5-EM | ASRock
Cooling 120MM Heatsink (2-FANs) | Custom HSK 90mm
Memory DDR2 2GB-x4=8GB | 8GB 2x4GB=8GB
Video Card(s) NVIDIA Quadro K2200 4GB | Intel
Storage 500\500/240/240GB SSDs 120GB Laptop IDE
Display(s) Asus 24"
Case DIYPC N1e-SPORT | CoolerMaster 110
Power Supply EVGA 550WATT | Rosewill 530WATT
Mouse Rosewill RGB
Keyboard Rosewill RGB
Software WiN10ET/WiN11ET
Yeah that "ONLY" is just a trick. You can use DDR2 on any Intel/AMD system. The whole "ONLY" is too scare you
1,457 (0.34/day)
Australia
True, I've used non QVL ram on many systems here & all is working well. QVL listing is only what vendors can get their hands on at the time of official testing, other than that, its overhyped.
