- Oct 9, 2007
- 47,904 (7.37/day)
- Dublin, Ireland
System Name | RBMK-1000 |
Memory | 2x 16GB DDR4-3200 |
Storage | Samsung 990 1TB |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
AMD today posted the latest version of Radeon Software Adrenalin 2020 Edition. Version 19.12.3 ships with a "focus on stability improvements," according to Terry Makedon, who heads the company's software strategy and user-experience. The company addressed close to two dozen issues related to the first Adrenalin 2020 Edition release (version 19.12.2). To begin with game and boost clocks incorrectly reporting for RX 5500 XT has been fixed. A bug with the installing failing to detect AMD graphics hardware when a certain WiFi adapter is enabled in the system has been fixed. A "Rocket League" application crash when task-switching has been fixed. The Radeon Overlay shortcut appearing in fullscreen 3D apps even after disabling Overlay, has been fixed.
A bug with streaming, where audio from custom scenes continues to play after recording has stopped, is fixed. The volume of the installer's splash screen audio has been reduced. Bugs with tessellation-related settings in Radeon Software have been fixed. ReLive missing or not being available for installation on some machines with Hyper-V enabled, has been fixed. Also fixed are buges related to newly added game profiles failing to enable. Performing an auto-update from Adrenalin 2019 (19.12.1 and older) to Adrenalin 2020 fails with an error code, which has been fixed now. Radeon Chill experience with "gaming mice" has been fixed. Stuttering observed when switching between borderless to fullscreen display modes in some games with Overlay enabled, has been fixed.
DOWNLOAD: AMD Radeon Software Adrenalin 19.12.3
Artifacting (black-outs) in "MechWarrior 5: Mercenaries" has been fixed. Radeon Anti-Lag failing to enable for DirectX 9 applications when globally enabled, has been fixed. Anti-Lag not engaging for "CS:GO" has also been fixed. Custom streaming failing to present users with a URL box to choose their endpoint, has been fixed. DirectML filters failing to apply upscaling and denoising when attempting to do both simultaneously on one image, has been fixed. Certain FreeSync display issued have been addressed. Scene editor not letting you set custom hotkeys has been fixed. Auto Tuning for Radeon RX 5700 XT resulting in extremely high/unstable OC has been fixed. Stability issues with Radeon Enhanced Sync have been addressed. RIS failing to enable in "Star Wars Jedi: The Fallen Order" has been fixed. And lastly, HDCP 2.2 protected content not playing back on some RX 500-series GPUs, has been fixed. AMD also identified a long list of issues it will address in future releases of Adrenalin 2020. AMD also added five new Vulkan API extensions, detailed below.
Fixed Issues
Known Issues
Fixed Issues
- Game and boost clocks may be incorrectly reported for Radeon RX 5500 XT graphics products in Radeon Software.
- Radeon Software Install may experience an error and fail to detect AMD graphics hardware when a certain WiFi adapter is enabled in the system.
- Rocket League may crash or experience an application hang after performing a task switch.
- A black screen may occur when Performance Metrics Overlay is open and changing game resolution.
- After disabling Radeon Software Overlay users may still see the toast messages for the overlay shortcut while in fullscreen games.
- Audio from custom scenes may continue to play after recording or streaming has been stopped.
- Installer audio has been reduced as it was too loud on some system configurations.
- Some users may be unable to select drop downs in graphics settings for Tessellation Mode.
- Radeon ReLive may appear to be missing or not available to install on some system configurations with Hyper-V enabled.
- Newly added game profiles may fail to enable the currently selected global graphics settings options in their profile.
- Performing an auto update from web to Adrenalin 2020 Edition from Adrenalin 2019 Edition may fail with an error code.
- Improved Radeon Chill experience when using a gaming mouse.
- Switching between borderless and fullscreen in some games when Performance Overlay is enabled and Radeon FreeSync is enabled may cause stuttering.
- MechWarrior 5: Mercenaries may experience black corruption near the bottom of the screen close to the player model.
- Radeon Anti-Lag may fail to enable for DirectX 9 applications when enabled in the global graphics settings options.
- Radeon Anti-Lag may fail to enable for Counter-Strike: Global Offensive.
- The custom stream option may fail to present users with a url box to choose their endpoint.
- DirectML Media Filters may fail to apply Upscale and Denoise when attempting to do both at the same time on one image.
- Some Radeon FreeSync enabled displays may experience LFC intermittently enabling mid game causing poor performance or stutter.
- A grey box may prevent users from setting custom hotkeys in the scene editor.
- Performing Auto Tuning for graphics clocks on Radeon RX 5700 XT may result in an extremely high OC or unstable OC.
- Some games may experience instability and screen loss or control loss when performing a task switch when the Gaming profile is set in Radeon Software which enables Radeon Enhanced Sync.
- Radeon Image Sharpening may fail to enable in Star Wars Jedi: Fallen Order.
- HDCP 2.2 enabled content may fail to play on some Radeon RX 500 series graphics products.
Known Issues
- Some Radeon R9 200, Radeon R9 300 and Radeon R9 Fury series graphics products may experience instability with a limited number of DirectX 9 or DirectX 11 games when using a high refresh rate 120hz+ display. A workaround if you are experiencing this issue is to lower your displays refresh rate.
- Trials Rising may experience excessive fog/smoke in some areas of the game.
- CPU usage may remain sometimes remain high once Radeon Game Advisor has been invoked during a game.
- Factory Reset install may keep previously configured Radeon Software game profiles. This can cause mismatch between global graphics settings and per profile settings.
- Text overflow in some UI boxes or toast messages may be experienced in some language localizations.
- Controls for vertical sync may be hidden or disappear when Radeon Enhanced Sync is enabled.
- Radeon Software may open with an inconsistent size or may not keep it's previously set size when opened.
- Some Vulkan gaming applications may crash when performing a task switch with Radeon Image Sharpening enabled.
- Integer Scaling may cause some video content to show flicker when the display resolution is set to less than native resolution.
- Performance Metrics Overlay may appear to lock frame rate at 60 fps when performing a task switch in or out of a game.
- Battlefield V may experience an application hang when changing settings in game with Radeon Boost enabled on Radeon RX 5700 series graphics products.
- Performing a resolution change while Radeon Software overlay is open may cause an application hang or TDR.
- Enabling Radeon Image Sharpening on HDR enabled displays may cause colors to become washed out.
- Mortal Kombat 11 may experience an application crash after the splash screen on Radeon RX 5700 series graphics products.
- SETI@Home may be provided incorrect results from Radeon RX 5700 series graphics products.
- VK_KHR_timeline_semaphore (Win7 Support): This extension introduces a new semaphore type that uses an integer payload to identify a point in a timeline. The extension supports querying the semaphore, host wait/signal operations, and device wait/signal operations.
- VK_KHR_shader_float_controls: This extension supports querying and overriding the default behavior of rounding modes, denormals, signed zero and infinity for floating point computations.
- VK_KHR_separate_depth_stencil_layouts: The extension separates the depth and stencil bits allowing their image layouts to be set independently.
- VK_EXT_tooling_info: This extension allows applications to query Vulkan tools that are active on the developer's system.
- VK_EXT_pipeline_creation_feedback: This extension adds a mechanism to provide feedback to an application about pipeline creation.
