AMD "Renoir" APU to Support LPDDR4X Memory and New Display Engine
47,657 (7.43/day)
AMD's next-generation "Renoir" APU, which succeeds the company's 12 nm "Picasso," will be the company's truly next-generation chip to feature an integrated graphics solution. It's unclear as of now, if the chip will be based on a monolithic die, or if it will be a multi-chip module of a 7 nm "Zen 2" chiplet paired with an enlarged I/O controller die that has the iGPU. We're getting confirmation on two key specs - one, that the iGPU will be based on the older "Vega" graphics architecture, albeit with an updated display engine to support the latest display standards; and two, that the processor's memory controller will support the latest LPDDR4X memory standard, at speeds of up to 4266 MHz DDR. In comparison, Intel's "Ice Lake-U" chip supports LPDDX4X up to 3733 MHz.
Code-lines pointing toward "Vega" graphics with an updated display controller mention the new DCN 2.1, found in AMD's new "Navi 10" GPU. This controller supports resolutions of up to 8K, DSC 1.2a, and new resolutions of 4K up to 240 Hz and 8K 60 Hz over a single cable, along with 30 bits per pixel color. The multimedia engine is also suitably updated to VCN 2.1 standard, and provides hardware-accelerated decoding for some of the newer video formats, such as VP9 and H.265 at up to 90 fps at 4K, and 8K up to 24 fps, and H.264 up to 150 fps at 4K. There's no word on when "Renoir" comes out, but a 2020 International CES unveil is likely.
2,771 (0.54/day)
Greece
Motherboard MSI B550 Tomahawk
Cooling ZALMAN CNPS9X OPTIMA
Case SHARKOON M25-W 7.1 BLACK
Keyboard Trust GXT280
Let's hope they manage to get it to work with very high speed memory in order to not get bottlenecked when both CPU and GPU parts are needed at full load. Then, we will have the best APU ever built to compete well against the low budget discrete GPUs. If priced correctly, it could easily become a best seller.
1,730 (0.76/day)
Motherboard MSI X670E Carbon
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Display(s) Samsung G8 OLED
Case Silverstone FT04
Hope we will see 6/8 cores APU from AMD
4,510 (1.39/day)
Currently Norway
System Name Bro2
Processor Ryzen 5800X
Cooling Corsair h115i pro rgb
Case Fractal Design G
Audio Device(s) Realtec 5.1
Mouse Logitech G402
Keyboard Logitech slim
Software Windows 10 64 bit
I was impressed what AMD does to the APUs and I wonder what this one will bring to the table.
3,986 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
Isn't that roadmap slide somewhat misleading when it comes to APUs? :)
Inflection - new process tech, new CPU core - doesn't quite describe Picasso.
1,065 (0.28/day)
System Name loon v4.0
Processor i7-11700K
Motherboard asus Z590TUF+wifi
Cooling Custom Loop
Memory ballistix 3600 cl16
Video Card(s) eVga 3060 xc
Storage WD sn570 1tb(nvme) SanDisk ultra 2tb(sata)
Display(s) cheap 1080&4K 60hz
Case Roswell Stryker
Power Supply eVGA supernova 750 G6
Mouse eats cheese
Keyboard warrior!
Benchmark Scores https://www.3dmark.com/spy/21765182 https://www.3dmark.com/pr/1114767
yay, new display engine!
(or am i excited over nothing?)
295 (0.11/day)
Integrated praphics should not be meant for gaming. The whole idea, that it should be good for low end gaming is really what is stopping AMD from getting additional money.
Intel CPUs are basically the No. 1 choice when it comes to office PC, home servers, work servers, worstations.
iGPU is only needed to show the view, and no workload is needed. We are buying things like 8700k, 9900k not because they are intel, but because they are powerful and have iGPU.
I wish AMD added iGPU into their high end models - NOT FOR GAMING.
While AMD is doing a good job on providing 4 core APU, it is however, based previous generation, which is not acceptable in my opinion.
3,152 (0.90/day)
Argentina
System Name Ciel / Akane
Keyboard VSG Alnilam / Dell
Another Vega, how boring.
3,986 (1.33/day)
When you look at the iGPU on a picture of a die in an average Intel's 24EU implementation EUs take up half or less of iGPU area. Rest are display engine and bunch of ASIC functionalities for video encode/decode and such.
There is definitely a sector where low-end gaming on an iGPU is a thing and AMD APUs have that sector locked down right now with 2200G/2400G/3200G/3400G. It is their decision to produce as few different dies as possible and the APU lineup is a result of that. Bigger CPUs without iGPU is also a clear decision, they would have needed a smaller iGPU for those or using the Vega would have pushed die size to too large.
4,510 (1.39/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
I see no sense in buying 9900K because it has iGPU. What's the point? You don't buy that CPU to browse internet or view emails do you? iGPU are not for gaming and then you say low end gaming. I really don't understand your logic. Low end gaming is what you get with this so why getting a 9900K with iGPU for low end gaming when you can settle on an APU 10 times cheaper and faster for games with the graphics it has at the same time? you dont need 8c/16t to play 720p games especially when you use iGPU.
3,986 (1.33/day)
I see no sense in buying 9900K because it has iGPU. What's the point? You don't buy that CPU to browse internet or view emails do you? iGPU are not for gaming and then you say low end gaming. I really don't understand your logic. Low end gaming is what you get with this so why getting an 9900K with iGPU for low end gaming when you can settle on an APU 10 times cheaper and faster for games with the graphics it has at the same time? you dont need 8c/16t to play 720p games especially when you use iGPU.
His point was that it is not for gaming. 9900K's iGPU is enough to get a picture on a screen. Non-GPU based productivity tasks is the obvious one here.
4,510 (1.39/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
He said Integrated graphics is not for gaming. That's in general not 9900K and he mentioned that low end gaming is what is stopping AMD from additional money? That's not true at all.
Adding an iGPU in the processor (not for gaming) is a waste of space. There's so many discrete cards and cheap.
Considering price of the 9900k and it's capability in the server market I strongly disagree this is the CPU to go for(just because it has iGPU) with it's limited PCI-e lanes I don't think so.
So basically I disagree with his post.
3,986 (1.33/day)
Cheapest PCI-e card I can see for sale is a GT720 at 30€ (this is from 2014). The cheapest current-ish generation card is GTX1030 at around 70€.
HDMI 2.0 you can get from GTX1030 at 70€, GPU with Displayport 1.2 can be had for about 90€.
71 (0.03/day)
I wouldn't run 4266mhz RAM on an AMD system that uses chiplets due to infinity fabric topping out at 4000mhz, as soon as you hit 2000mhz, infinity fabric scales back and doubles the multiplier making the rest of the system slower.
For this reason, they should use monolithic typology.
4,510 (1.39/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
I can see a gpu for a $22 on eBay (new card). 9900k I could find for $610 cheapest. Well the 22 buks is like nothing and considering the price of a 9900k I'd go with something else and save some cash or go for better GPU. For example 3800X for $400. That gives you over $200 for a GPU. And there's motherboards and other components. I'm sure that margin would grow even higher.
Unless you go APU and call it a day but this is for the server market so 3800X is more than enough for home workstation or home server and cheaper and the difference in performance between 9900K and 3800X is negligible
3,986 (1.33/day)
9900K was an example, the same questions apply to anything i5 and above. This class of CPUs start at below 200.
1440p or 2160p monitors are pretty commonplace, usually with Displayport 1.2 for connector.
Prices do differ between regions, I suppose. In EU 9900K can be had for 475€, 3800X is 389€ and 3700X is 335€.
bug
14,337 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Imho, IGPs should be kept tiny. They're meant to display your Office suite/browser and as a failsafe when your dGPU acts up. I see no value in wasting 33% or more die area for that.
4,510 (1.39/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
Of course there is no point for wasting area. Actually I think in the High end the iGPU is a waste, you can still get a discrete gpu cheap.
853 (0.31/day)
Asia
Processor Intel Core i5 4590
Cooling Intel Stock Cooler
Power Supply Corsair VS450
Mouse A4Tech N-70FX
Picasso is Zen+ with GoFlo 12nm compared to Zen with GoFlo 14nm on Raven Ridge.
7,832 (1.78/day)
Well first of all we don't know whether the infinity fabric & memory (real) clocks are at 1:1 for the APU, second we also don't know whether infinity fabric is for instance limited by the (chiplet) design or memory controller, maybe something else entirely? So you're basically guessing at this point about how IF could be a hindrance in this case.
Yeah monolithic design is definitely what I'd prefer as well, but then we'll have to see the economics of that.
419 (0.20/day)
Processor R5 5600X
Memory 32 GB 3600 MT/s CL16
Video Card(s) Sapphire Vega 64
Storage 2x 500 GB SSD, 2x 3 TB HDD
Case Phanteks P300A
Software Manjaro Linux, W10 if I have to
Ah, too bad it won't be using Navi GPU. Let's wait for reviews, but I might skip this gen as well until we get 7 nm GPU/CPU APU.
bug
14,337 (3.95/day)
It's not using Zen2 either, so no surprise there ;)
9,217 (4.08/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
My experience with STAPM and a couple of 2000-series APUs is that AMD are so nearly there with their current-gen APUs. Battery life suffers compared to Intel because AMD's 1st-gen Zen/Zen+ CPU cores seem to eat up power at lower clockspeeds and don't clock down as hard as Intel's U-series do when idle.
I actually think that getting the CPU portion of the power draw down is more important that the Vega IGP, so if Renoir APUs are 7nm Zen2 cores and 12nm IGP and IO, they'll be fine.
Ideally, the whole thing will be at 7nm but with the 2700U I bought myself in February, and with some STAPM power-budget tweaking thanks to modified BIOSes and RyzenAdj, I can say for certain that the 4C/8T of Raven Ridge load can comfortably use 15-18W and will never consume less than 5W in a normal system. The Vega10 IGP will add maybe 8-9W at full load and peak clocks but rarely get to run at those speeds because most laptops OEMs set a STAPM limit of somewhere between 15-25W (20W in my case). That means that before long, the CPU is using the lion's share of the power budget and the Vega cores are throttled back to 25% of their ideal clocks, despite being the more important part of the equation when the IGP is active in a 3D or GPGPU compute application.
At 15-18W potential peak CPU core usage the IGP really suffers in a Ryzen APU, and most people will be buying Mobile Ryzen for the Vega cores, otherwise they'd just get an Intel with worse graphics but better battery life. In the case of the 15W ultrabooks, the IGP is throttled down to pointless speeds. In the case of 20W and 25W models, the IGP is running sub-optimally if the CPU is busy. TSMC's 7nm seems to have huge efficiency gains so even if ONLY the CPU cores in Renoir were moved to 7nm, that 15-18W CPU peak draw could drop down to Maybe 10-12W, leaving far more headroom for the IGP to do their thing in the ideal 15W power budget.
My preference would be for AMD to better balance their APU power budget in hardware so that the Vega cores get first dibs on whatever power is available. It's actually self-balancing, because if the CPU clocks drop too far from IGP greed, the IGP will stall and free up power budget for the CPU. The current CPU-first implementation doesn't really work. The CPU clocks up and overfeeds the IGP which then rejects frames because it can't process them fast enough. It's a stupid waste :(
3,986 (1.33/day)
bug
14,337 (3.95/day)
