AMD Ryzen AI 9 300 Posts a 20% Performance Upgrade with Both Graphics and CPU Over Previous Gen
47,662 (7.43/day)
The top-spec AMD Ryzen AI 9 300 series "Strix Point" processor, the Ryzen AI 9 HX 370, is expected to post a 20% performance improvement over both the CPU and integrated graphics fronts, over its predecessor, the Ryzen 9 8945HS "Hawk Point," according to leak by Golden Pig Upgrade. On the CPU front, the HX 370 packs a 12-core/24-thread CPU based on a combination of four "Zen 5" and eight "Zen 5c" cores. The single-thread performance gains on the basis of the "Zen 5" microarchitecture's generational IPC increase, besides higher clock speeds; while the multithreaded performance increases on account on more cores. This performance increase isn't linearly scaling with the 50% increase in core-count.
On "Hawk Point," all eight cores are "Zen 4," capable of boosting to high frequencies, with two of them being marked as CPPC preferred cores, capable of boosting the highest. On "Strix Point," however, only four cores are based on the "Zen 5" architecture and capable of boosting to high frequency bands; while the other eight are "Zen 5c," which don't boost as high. While the IPC of "Zen 5c" is identical to "Zen 5," the fact that it doesn't boost as high, means that the generational multithreaded performance gain from the core-count increase is expected to be closer to 20%, with Golden Pig Upgrade talking about a Cinebench R23 nT score of over 20000 points, with "Hawk Point" scoring around 16000 points.
Things get interesting with graphics. The new RDNA 3.5 iGPU on "Strix Point" packs 16 compute units (CU), compared to 12 CU on the "Hawk Point." These 16 CU work out to 1,024 stream processors, a 33% increase over the 768 stream processors of "Hawk Point," and yet there are many other factors that decide graphics performance besides CU count, and so Golden Pig Upgrade expects a 20% graphics performance improvement, which should make the new iGPU beat the Intel Arc Xe-LPG graphics of Core Ultra "Meteor Lake" processors by at least 20%. AMD, in its product announcement slide, claimed a 36% graphics performance lead over the Arc Graphics iGPU of the Core Ultra 9 185H processor.
As for the NPU, AMD has already claimed an AI inferencing performance of 50 TOPS, which goes a fair bit above the 40 TOPS required to meet Microsoft's Copilot+ AI PC program. This figure of NPU performance is needed for Windows to run local sessions of Copilot, minimizing back-and-forth from the Cloud, and improving privacy.
274 (0.73/day)
System Name Main Workstation
Processor AMD Ryzen Threadripper 2970WX PBO 3,6-4,2Ghz
Motherboard ASUS ROG Zenith Extreme + Extreme Cooling Kit
Cooling Alphacool Eisbaer Aurora Pro 420
Memory 8x16GB (128) Kingston Fury RGB @3266Mts 16-18-18-36-74 2T
Video Card(s) RTX 3090 ROG Gaming OC @1500Mhz (1965Boost)
Storage Lexar NM790 2TB, Corsair Force MP510 960Gb, Samsung 860 SATA 2TB, 2TB WD Green 7200rpm
Case Phanteks Ethoo Pro 2 TG
Power Supply EVGA Super Nova 1000GT
I dont care if the cpu increases performance by 90000% and makes my breakfast. The naming scheme now has arrived at such a high level of BS where I simply refuse to buy until they are back at a comprehensive level.
660 (0.15/day)
Well if you extrapolate those iGPU numbers, in raw numbers at least, the new Arc Xe2 iGPU in the Lunar Lake chips, should be faster than this. Intel claimed a 50% uplift. It will be interesting to see if its the case.
830 (1.15/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
I'm sure they'll fix it when an AMD rep sees this post so they don't lose out on the sale of one processer from you
bug
14,340 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
20% more at the same TDP is quiet respectable, no doubt about that.
4,118 (2.61/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
There'a processor for everyone. Ryzen 9X AI-TXT-XTX moreX-moreAI 19950X-3D+3D for me, it will trade AMD stock, forge my tax returns and indirectly make my lunch all by itself. Intel® Processor 300 for you.
15,731 (6.85/day)
Midlands, UK
Processor AMD Ryzen 7 7800X3D @ 45 W TDP Eco Mode
Case Corsair Crystal 280X
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
With this stupid naming, you don't even know what the previous gen is anymore.
1,371 (1.02/day)
Tell people with weird names that they could only become your friends if they change their names to John and Mary.
It's heavily optimized TimeSpy where Intel iGPU scores proportionally higher than competition, in comparison to real life workloads.
274 (0.73/day)
Thats exactly the reason why nicknames exist. Too many unstreamlined Names. And its sad we need them for Hardware now. Otherwise you need a codewheel to decipher what a product actually resembles.
1,371 (1.02/day)
It'd be good to clarify to readers that the posted score in TimeSpy is desktop iGPU 780M on 8700G, the chip that consumers more power. Mobile iGPU 780M graphics scores are on average lower, around ~3060.
Yes, it's called Strix. That's all you need to know.
If you want the top model, look for the number 370, or look into spec that reads 12 cores.
So, you have several hints: Ryzen 9, Strix, 370 or 12 cores.
What else do you need to be happy?
15,731 (6.85/day)
Midlands, UK
They've already explained that people hated the older naming, so they changed it.
Right now it looks like revenge, tho.
People hated the naming because instead of product generations, the numbers meant release years. So if they released a Zen 3 CPU a year after a Zen 4 one, it would bear a higher number. And now, the new name means absolutely nothing, but has "AI" in it to make investors happy, I guess. They effectively turned bad to worse.
2,412 (0.81/day)
Tanagra
System Name Mac mini
Processor Apple M1 8C
Motherboard Mac mini logic board
Cooling Mac mini cooler
Memory 16GB
Video Card(s) M1 GPU
Storage 512GB
Display(s) ASUS Pro Art 27"
Case Mac mini enclosure
Power Supply Apple 150W
CPU names haven't made sense for at least a decade, but as long as you can search whatever name they give them and get the right result, then whatever. Honestly, it was about time for renaming anyway since they were about to clear the 10k mark. I didn't care for AMD's old mobile approach, which didn't follow the desktop SKUs at all, but they did that in order to sell various generations at the same time but make them all look current.
bug
14,340 (3.95/day)
For a company that just loves to mix several generations (CPUs or GPUs) under the same naming, that would be "mission accomplished", wouldn't it? ;)
Ruru
S.T.A.R.S.
13,792 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
The naming is becoming as confusing as Intel's with their Core Ultras.
bug
14,340 (3.95/day)
It's not doing us any favor, but let's be honest: those the could see past the name on the box will continue to do so, the others will keep buying the higher number, as usual.
Ruru
S.T.A.R.S.
13,792 (3.05/day)
Jyväskylä, Finland
Yeah, true. The same goes for GPUs when there are so many SKUs with similar naming etc.
  • Like
Reactions: bug
bug
14,340 (3.95/day)
They should just name all their CPUs...Bob.
Slow Bob
Medium Bob
Fast Bob
Faster Bob
That's how I read naming schemes anyway.
Ever since we've gone multicore, any number on a box became useless. You really need to understand how the CPU is built in order to determine if it fits your needs.
Do I need more cores? Do I need faster cores? Do I need more cache? Do I need more memory channels? No naming scheme will help you to answer that.
261 (0.15/day)
So Time Spy CPU, 13.5k which is about 15% better than the current 8945HS which is around 11.8K, which my current 2020 laptop (4900HS) is around 9.4k which is about a 44% increase... so yea, it might be worth upgrading at some point...
3,090 (0.53/day)
MN
System Name Personal / HTPC
Case Titan Silent 2 / CM HAF XB Evo
I don't even know what CPU this is supposed to be. Clearly I'm not their market, but I have no idea what CPU this is and what CPU was it's predecessor.
SL2
2,530 (0.36/day)
Someone said that it starts with 3 because it's the third (don't debate me, I'm the messenger) generation with an NPU. (And yeah, AMD want's to be ahead of Intel's upcoming 200)
It's the first APU with 12 cores, so it's quite a step up from 4000/5000/6000/7040(8000) which has 8. Graphics is now 16 CU instead of 12.
There are only two models, 365 and 370, with 10 or 12 cores, 4 regular Zen5 cores and the rest Zen5C cores.
23,888 (6.16/day)
If that's the case I can't wait for the many lost sales after they fell back to 100's for these CPUs...
I mean, I'll take one that's over 9000 directly! But this?
Slow Bob
Medium Bob
Fast Bob
Faster Bob
Next gen: Hank.
Oh yeah I want this. If you think of it, Nvidia's already kinda doing it. Ampere, Ada...
1,898 (1.46/day)
System Name Raspberry Pi 7 Quantum @ Overclocked.
They claimed it was 50% faster than a "ULV" meteor lake chip with 4CU/XEs iGPU (Half of the 155/185H model).
