AMD-V not recognized on B550 Phantom Gaming-ITX/ax with R7-3800x
3,741 (1.77/day)
Power Supply Corsair RM750x
Mouse Logitech M575
According to https://www.techpowerup.com/cpu-specs/ryzen-7-3800x.c2129 and https://en.wikichip.org/wiki/amd/ryzen_7/3800x AMD-V should be supported by this CPU but on my B550 Phantom Gaming-ITX/ax I can't get HWiNFO64 or VMWare Workstation to recognize it even though I have it enabled in UEFI/BIOS. Oddly enough Task Manager indicates virtualization is enabled but these two software can't recognize it.
I need AMD-V in order to enable and use a VMWare Workstation Virtual Machine that requires virtualization to be enabled for certain software.
I was hoping someone familiar with AMD-V support and VMWare workstation might have a solution.
Previously this worked with Windows 10 and VMWare on my Master SLI/ac with 3950x and 5950x before it exploded in a puff of smoke. My original setup came up from upgrades to Windows 10 v1903, while my ITX was a fresh install of a much more recent version (maybe v2004 or v21H2).
Maybe the relative setting to that feature in the UEFI needs to be enabled?
It's called SVM and it's enabled in UEFI.
After searching the better part of the day I finally found the solution. https://www.hwinfo.com/forum/thread...d-in-bios-yet-amd-v-disabled.8201/#post-35995
bcdedit /set hypervisorlaunchtype off
There must have been some kind of change to how Windows handles hypervisors between older and newer versions of Windows 10 installations.
