- Aug 19, 2017
- 3,262 (1.13/day)
According to one of the most reliable AMD leakers, Kepler_L2, AMD's upcoming UDNA (or RDNA 5) GPU generation will reintroduce higher-end GPU configurations with up to 96 Compute Units (CUs) in the top-end Navi 5X SKU, paired with a 384-bit bus for memory. We still don't know what type of memory AMD will ultimately use, but an early assumption could be that GDDR7 is on the table. When it comes to the middle of the stack, AMD plans a GPU with 64 CUs and a 256-bit memory bus, along with various variations of CUs and memory capacities around that. For the entry-level models, AMD could deliver a 32 CU configuration paired with a 128-bit memory bus. So far, memory capacities are unknown and may be subject to change as AMD finalizes its GPU lineup.
After the RDNA 4 generation, which left AMD without a top-end contender, fighting for the middle-end market share, a UDNA / RDNA 5 will be a welcome addition. We are looking forward to seeing what UDNA design is capable of and what microarchitectural changes AMD has designed. Mass production of these GPUs is expected in Q2 2026, so availability is anticipated in the second half of 2026. A clearer picture of the exact memory capacity and type will emerge as we approach launch.
