Amdvbflash and RX 590GME bios issues
y4u
7 (0.01/day)
amdvbflash old version:unlockrom success, but appear “adapter not found ,error:0fl01”
amdvbflash new version:can read something, but appear “VBIOS related functionality not supported for Device: 0x6fdf”
gpu-z can identify devices!Device Manager can display devices!
so,what's the matter with it ?
Which old version did you try?
Please use amdvbflash v2.93.
If v2.93 doesn't work, you can try v3.31 but be aware the command syntax is different!
Please use amdvbflash v2.93. If v2.93 doesn't work, you can try v3.31 but be aware the command syntax is different!
new problem,v3.31 reminder id do not match,i can change the id,but it unable to install the graphics drive
and v2.93 doesn't work,reminder adapter not found
Reminder? Sorry, you are very unclear. Please make a screenshot of the error message and the command which you are trying to use.
You are cross flashing to a different model so it isnt strange you get this error message mesage.
amdvbflash 3.31 doesn't allow bypassing the SSID check.
Yes,2.93 can flashing to a different model,but it dosen't work on this 590GMEo_O, "adapter not found ":(
Maybe you can try to follow the steps describe in this thread:
Thank you!
now, i know what i can do.
the key is the 590GME vbios, is a special vbios——2.93 cannot detect this card,but 3.31 can.
firstly i can use PolarisBiosEditor edit device ID.
secondly use 3.31 flash to the card.
then , 2.93 able to detect this card.
finally, i can use 2.93 flash to it.
