android recovery and kernel.img
is it safe to flash the generic rk3066 cwm and wouldn't lead to a brick?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 1 100.0%
  • Total voters
    1
259 (0.06/day)
System Name The Tamed Beast / LAVA ETAB XTRON+/Mipad/Mi Max
Processor Intel Core i3-3220 X4 3rd gen Ivy Bridge with Hyperthreading / Cortex A9 1.6 Ghz X2/
Motherboard Gigabyte GA-B75-D3H Ultra Durable 4 classic Socket 1155 / RK3066
Cooling Stock
Memory G. Skill RipjawsX 2X2=4GB running at 1600 Mhz / 1GB DDR3
Video Card(s) ZT-61201-10M ZOTAC GeForce GTX 650 Ti Boost 2GB 192-bit GDDR5 (Editor's Choice)/MALI 400 MP4@250 Mhz
Storage WD10EZRX 1TB Single Platter "Green"HDD / 8GB NAND FLASH, 16 GB San Disk Class 10 Ultra Micro SD
Display(s) Dell IN2030M TN LED backlit LCD (1600x900) / 1024X600 7" IPS
Case Cooler Master K281 Plus
Audio Device(s) Stock (Motherboard)
Power Supply Builder Series™ CX430 V2 — 80 PLUS® Certified Power Supply (28A at 12V)
Software Iobit ASC & Smart Defrag, WinPatrol, Utorrent, CCleaner , Nvidia Inspector, KIS
Benchmark Scores 47.2fps and 39.8 fps at 1600x900 in valley extreme 4xaa and 8xaa (ultra) 63.9 fps in Nenamark 2
here http://forum.xda-developers.com/showpost.php?p=51655449&postcount=706, he said that if the first word of the kernel .img is krnl then I can flash it, device is lava etab xtron plus rk3066 and I'm trying to install cwm, I have uploaded the file some how it was saying file too large so had to break it, any help here is appreciated (problem is that xda members are not quickly responsive like you guys), I have already rooted...THE FIRST WORD OF HEX OF KERNEL.IMG IS KRNL$x
Model:JB7+
Battery:65%
Firmware version:4.2.2
Wi-Fi:Off
Status:ROOTED
Resolution:1024*600
Manufacturer:Unknown
Serial:0123456789ABCDEF
IMEI:Unknown
IMSI:Unknown
MAC:Unknown
Android Version:4.2.2
Baseband version:Unknown
Kernel version:rk30sdk-user 4.2.2 JDQ39 eng.dzy.20130506.194800 test-keys
i think you're going well beyond generic android help here.
i've flashed and modded a dozen devices, and have no idea what you're talking about.
For thouse who CAN help...:I can't enter adb (device not recognized), can't flash using stock recovery (don't really know the steps and stuck at triage and dead android when in recovery),
IF you cannot enter ADB then your drivers are not working. Download the proper drivers for the device and do adb.exe devices to see if it shows anything
problem is from where, even for rooting I had to install mobobo (or somehitng like that) to get win usb and it is still installed it shows the device as adb composite and the adb is not recognizing, can you find the right friver for me , have been searching up and down for them and the rockchip ones are somehow not installing saying that there is no device selected for device information set or element and other times it is not even getting to there even...I'm also facing code 28, I'm on the verge of giving up!EDIT :SORRY NO CODE 28
YEAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHH,, FINALLY DID IT, my palms were sweaty, knees weak and arms were heavy when I was doing it.. but I DID IT!! YEAH just for info I did it by using the arc tools from here afte veryfing that the recovery was the one being distributed here I sacked up and flashed it... I was sucessful, and what do you think should I do a cmplete guide for rooting and cwm for lava tab huh?
Dude, no offense, but I check TPU at least 20 times a day, and your last few topics are...well....bizarre to say the least. I get it, that you were looking for some cheap tablet in India and then you wanted to flash it with newer android version, but really, why bother opening a thread at all when: 1.) you reply to every suggestion with: I LIVE IN INDIA MAN! (you could always fill in location in your profile and we will know with just one glance), and 2.) You give very little initial information when opening the thread. If I hadn't known about you previous purchase- this topic right now would be a mystery to me. You have more than decent English, and that's commendable. But what you write stays on the forum, that's your reputation/credibility, and when you open topics like that it makes me think whether I want to read your next thread :) I'd highly suggest when you make your guide about the Lava tablet - make a draft, wait for a few days and read it again to be sure you explained everything well enough- from the model of the tablet to what you did to it:) I am not being negative (at least I hope I am not :) ), it's just I feel you are making a bad rep for yourself :)
Nevermind: discard what I said. It's off topic and I could've written in PM. Sry about that.
Ohh Just wait a second, I have only wrote that my location is India about 2 times (well, I only really remember one time), and only that when the other guy suggest something from newegg or amazom.COM or ebay, secondly I didn't really knew how to fill in Country will do thanks for the tip, and yes you are right I give very less early info, well the problem with me is I seem to ask the question to myself first and then write it down, without really thinking about it okay...good tip..Well, okay I will make a guide for the tab along with a short review..thanks for the tips...
EDIT:here is the link to the guide http://www.techpowerup.com/forums/t...r-lava-etab-xtron-rk3066.199623/#post-3090794
