Android Updating issues
iPhone or Android
  • Total voters
    5
98 (0.03/day)
A dusty server room
System Name HP DL380 G5
Processor 2x Intel Xeon X5460 @3.16 Ghz
Motherboard HP DL 380
Cooling 6 60mm intake fans rated for 14k RPM max load
Memory 16GB of DDR2 667Mhz
Video Card(s) AMD XFX R7 360
Storage 3x 140GB 10K SAS JBOD
Display(s) 1x Hisense 42" TV
Case DL 380 G5
Audio Device(s) HDMI Out
Power Supply 2x 800w Proprietary PSUs
Mouse A cheap logitech wireless mouse
Keyboard Acer KU-0355
Software Windows 10!
Benchmark Scores Ill get around to em soon
Good afternoon lads, I have encountered a strange issue.
I am running Android Lollipop 5.1 and wishing to run android 6.x or greater.
Whenever I go to my "About phone" > "System Updates", All I see is an option called "Storage card updates", Which I have no idea what those mean and I'm left without a clear option to update my phone. Any help is greatly appreciated
Wow. I logged in for the first time in, like, years, just to answer this.
As far as I know, there are exactly 2 (two) phones that run Android that receive Android updates immediately - they are the Google Pixel and Google Pixel XL. Go figure.
Now, why is this?
Wireless carriers (again, here is that as far as I know qualifier) that carries Android phones load their own customized version of of the Android OS onto those phones. That means that the same wireless carrier must also customize each Android update. This is very time consuming, annoying, and frankly, costly. There is basically no return on investment for wireless carriers to support further updates.
The same can be said for mobile manufacturers. For example, I have a Samsung Galaxy Note tablet. I love it. It does not have the capability to connect to a cell network, it is wifi only. Now, there is no wireless carrier involved here, right? Right! However, now the manufacturer of the mobile device has to support these updates, because manufacturers also use their own customized Android versions. But I'm not paying a subscription to Samsung. They are literally making zero money off of me once I buy that tablet. So manufacturers also have little to no return on investment (and therefore incentive) to push out their custom versions of Android as well.
Another point: Every different mobile device running android has to run a different version per phone. This isn't a manufacturer or wireless carrier being a dick, it's just the way things are and need to be, and is required because phones have different hardware. So, even if the manufacturer/wireless carrier isn't running their own customized version of Android, each model of device still needs it's own version of stock Android. And now we go back to that ROI things that manufacturers feel there is little of.
So, why are Google phones different? Because Google mandates that their phones run STOCK Android! And there are only 2, with very similar hardware. This makes it much easier for Google to support their phones with updated versions of Android.
Now, your next question should be "Well, how do I run an updated version of Android??"
The solution is that you must run an 'after-market' (that's the wrong term, but the meaning is analogous) version of Android such as CyanogenMod. There are also other versions/communities, but I'm not familiar with those. Many of these communities have guides on how to install and run Android on your phone.
There is something to be aware of here. As I said above, every phone requires a different compilation of the OS. So many sure you choose the right version for your phone, and the right install guide for your phone.
EDIT: forgot a letter in a word
Which phone are you trying to update? Make, and model?
Now, why is this?
This is all correct.
Some manufacturers are better than others though, Sony for instance have lots of updates over time. I'm about to get a Samsung S7 and already worry about whether it will get any new updates at all. The good thing about flagships is that they have lots of mods.
