pjladyfox
- May 8, 2008
- 232 (0.04/day)
System Name | Eternal |
Processor | AMD Phenom II 955 |
Motherboard | Gigabyte GA-MA790X-UD4P |
Cooling | Corsair H50 water cooling system |
Memory | 8GB Corsair TWIN2X2048-6400C5DHX |
Video Card(s) | ATI Radeon HD 5870 |
Storage | Seagate 7200.10 250GB SATA2, 7200.11 750GB SATA2, and 7200.10 500GB SATA2 |
Display(s) | SAMSUNG 245BW 24" LCD |
Case | Antec Three Hundred - custom mnpctech.com |
Audio Device(s) | Realtek ALC889 onboard sound |
Power Supply | Corsair HX620 |
Software | Windows 7 Home 64-bit Retail |
I came across these cases quite by accident when doing my usual tech website reading and was surprised to see that, at least according to my search, nobody had posted about these cases yet. So, I did some digging and came up with some websites and pictures that showcase them with the idea of getting some conversation going. ^_^
News articles:
CES 2010 PCWorld.fr
http://www.pcworld.fr/2010/01/10/materiel/boitier/ces-2010-nouveaux-boitiers-antec/468641/
CES 2010 Japanese tech blog
http://journal.mycom.co.jp/articles/2010/01/18/ces10/index.html
CES 2010: Antec
http://www.techwarelabs.com/ces-2010-antec/
CES 2010: Antec showcase
http://www.pcper.com/comments.php?nid=8230
Antec Introduces Latest PC Casings And Power Supplies At CES 2010
http://www.hardwarezone.com.ph/news/view.php?id=15636&cid=3
CES 2010 - Antec
http://www.overclockersclub.com/reviews/ces2010/17.htm
Notes:
- DF-30 appears to have similar dimensions to the 200/300/600 and is most likely a mid-tower
- DF-85 appears to have similar dimensions to the 1200 and is most likely a full-tower case
- both DF-30 and DF-85 appear to have removable filters similar to the Antec 902 and 1200
- both DF-30 and DF-85 have provision for a top-mounted 2.5 SATA drive and appears to be hot-swappable
- both DF-30 and DF-85 have tri-cool fan controls mounted in the rear top of the case similar to the 600/900/902/1200 cases
- both DF-30 and DF-85 STILL do not have provision for mounting the PSU fan-side down
- DF-30 STILL does not have any motherboard routing holes (WTF Antec??!!)
- DF-30 STILL is not sufficiently long enough in order to accomodate all 3.5 drive bays being filled with 270mm long video card being present
- DF-30 STILL does not appear to be long enough to accomodate 310mm cards such as the HD 5970
Unanswered questions:
- what are the actual dimensions of the DF-30 and DF-85?
- are the size of the upper fan mounts on the DF-30 and DF-85?
- When will these be available?
News articles:
CES 2010 PCWorld.fr
CES 2010: Antec
CES 2010 - Antec
Notes:
