- Dec 16, 2010
- 1,685 (0.32/day)
- State College, PA, US
System Name | My Surround PC |
Processor | AMD Ryzen 9 7950X3D |
Motherboard | ASUS STRIX X670E-F |
Cooling | Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans |
Memory | 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30 |
Video Card(s) | MSI NVIDIA GeForce RTX 4090 Suprim X 24GB |
Storage | WD SN850 2TB, Samsung PM981a 1TB, 4 x 4TB + 1 x 10TB HGST NAS HDD for Windows Storage Spaces |
Display(s) | 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD |
Case | NZXT Source 530 |
Audio Device(s) | Sony MDR-7506 / Logitech Z-5500 5.1 |
Power Supply | Corsair RM1000x 1 kW |
Mouse | Patriot Viper V560 |
Keyboard | Corsair K100 |
VR HMD | HP Reverb G2 |
Software | Windows 11 Pro x64 |
Benchmark Scores | Mellanox ConnectX-3 10 Gb/s Fiber Network Card |
I'm having trouble with my RTX 4090's power limit. GPU-Z reports a "PWR" limiter whenever the GPU gets to 450W power draw. The card I have should have a 480W power limit by default, and when I set the power limit to 110%, that should raise it to 530W.
I suspect that the 12VHPWR cable connecting my PSU to my GPU is the culprit because it's seems too coincidental that the power limit is exactly 450W, which would be the cable limit if one of the sense pins was not properly connected. However, I have checked the plug with a multimeter and both sense pins are connected to neutral since there is continuity when touching a sense pin and any other black wire coming from my PSU.
Before I go further with the hardware investigation, is there a way in software to confirm that the cable (and not software) is limiting the card to 450W? I could not find anything in NVIDIA's control panel, in GPU-z, or through an internet search that will report the power limit of the cable.
