Any way to overclock cpu?
1,034 (0.17/day)
Scotland
Processor Phenom II X4 B50 @ 3.4Ghz
Motherboard Gigabyte GA MA790XT-UD4P
Cooling Vendetta 2, several case fans
Memory 8GB Geil Ripjaws 1666Mhz
Video Card(s) Powercolor 5850 1GB
Storage 1TB Samsung F1
Display(s) LG 23" W2361V TFT Widescreen
Case Antec 300
Audio Device(s) X-Fi Xtreme Music
Power Supply Antec HCG 750W
Software Windows 7 Pro 64bit
I've just upgraded my friends pc to a 4870 and it seems to be bottlenecked a bit by his e6550 @ 2.33ghz. The mobo is an OEM board (ASUS IPIBL-LA (Berkeley), he has a compaq) so there are no overclocking options in the bios. I tried SetFSB but it didn't seem to work well, basically it just slowed the computer down and made everything unresponsive. This might have been down to his RAM tho, (he has 2gb oem ram rated at 667mhz and 2gb kingston hyper x rated at 800mhz).
So basically my questions are: will the e6550 be a big bottleneck and if so is there any way I can overclock?
Hmmm, I was thinking you can do a physical pin mod (BSEL mod) to increase the FSB, but since stock is 333mhz, the next step would be 400mhz and I doubt an OEM board would be capable of that frequency. Sorry, but I don't think you'll get anywhere without a new motherboard. :ohwell:
Don't worry too much about it being bottlenecked by the CPU, more by the 2GB of ram, and probably the a 32bit OS ;)
For set clock if the software does not detect correctly the clock generator you should experiment to see which would work for that board. I`v had P7N SLI that was not detected and from searching on the net I did not find which one is correct so I was trying every clock gen and trying only those ones that detect correctly the FSB and multi. And it worked for E5200 @ 4.8GHz :D
