Anyway to get rid of annoying nVidia System Tray icon?
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
So with the last few nVidia drivers they've added a very annoying System Tray icon that is there when the computer starts. I don't know why, but it bugs the crap out of me.
Now I can stop the "NVIDIA Display Driver Service" service and the icon goes away. Oddly, I can start the service right back up again and the icon doesn't come back.
Now for the mean time I just wrote a bat file that runs at startup to restart the service, which gets rid of the icon, but there has to be a better way. Perhaps some option burried somewhere in the nVidia control panel or something.:banghead:
2,350 (0.43/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
How about open the icon, find "Desktop" tab, at top left, and uncheck "show notification tray icon"
Easy Rhino
Linux Advocate
15,685 (2.33/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
that should do it...
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
http://img.techpowerup.org/110701/Capture701.jpg
Yeah, it is already unchecked, that is why I started the thread. Sorry, meant to mention that in the first post.:eek:
Edit: Just driver sweepered, re-installed drivers, and rebooted. The icon still popped up. I went into the control panel and it was still unchecked despite the icon being there. I check the option, unchecked it and the icon went away. I rebooted and no more icon. Odd, but I'm happy.
Easy Rhino
Linux Advocate
15,685 (2.33/day)
Mid-Atlantic
System Name Desktop
Mouse MX Master 3s
i am also anal about the taskbar.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
I'm not as bad as some, I can handle icons down there that actually serve a purpose. Like the icon for my UPS that controls the computer in case of a power outage and gives me health status of the UPS, or the RAID icon that tells me the status of my RAID array in my main machine and my business server. But icons that have no purpose at all, like the nVidia one, bug the crap out of me...:laugh:
Zyon
264 (0.05/day)
Australia
System Name Computernamehere/Computernamehere2/Computernamehere3
Processor i5-2500/Athlon 6000+/C2D Q6700
Motherboard P67A-UD3R/M2N-SLI Deluxe/P5K-Deluxe
Cooling Stock/Hyper212+/Unknown Coolermaster
Memory Patriot PC3-10666 2x2/A-Data PC2-6400 4x1/OCZ PC2-8500 4x1
Video Card(s) MSI GTX580 Lightning/2x Gigabyte GTS450 OC 1GB/2x HIS HD4870 512MB
Storage Seagate 1TB/Samsung 500GB/Seagate 1TB
Display(s) Samsung BX2440
Case V4 Black/Mystique 631 Silver/Soprano VX
Audio Device(s) WTF is a sound card?
Power Supply Corsair HX650/Antec Earthwatts 650W Green/None
Software Windows 7 Home/Professional/Professional
Benchmark Scores TBA
You could play around with the registry and disable Nvidia tray from starting up with your Windows.
toofat
1 (0.00/day)
Just wanted to reply because I was seraching for solution and it was like 3rd option on Google. Finally found solution myself.
1. I have tried unchecking "Show Tray Icon" ... doesn't work
2. I have tried installing only "Display adapter drivers" and "Physics" (with clean install) ... doesn't work
What happens. When you deselect "Show Tray Icon" app sets REG "HKEY_CURRENT_USER\SOFTWARE\NVIDIA Corporation\NvTray\StartOnLogin" to DWORD 0 ... but this doesn't work because there is no coresponding value under "HKEY_LOCAL_MACHINE". So to fix this you have to add REG
[HKEY_CURRENT_USER\SOFTWARE\NVIDIA Corporation\NvTray]
"StartOnLogin"=DWORD:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\NvTray]
5,226 (0.82/day)
System Name Addison Clark
Processor Ryzen 9 7950x3D delid
Motherboard Asus X670E Hero
Cooling Custom Bykski loop CPU, GPU, 2x 360 rads, and 1x 280 rad with Arctic P12 and P14 ARGB fans
Memory G.Skill DDR5-6000 64GB CL30
Video Card(s) Gigabyte 4090 Aorus Master
Storage Kingston Fury 2TB and 4TB NVME
Display(s) Samsung 57"
Case Lian Li O11 mini
Power Supply Thermaltake 1000w SFX-L
Keyboard Corsair K95 Platnium
Software Win 11 Pro
Is hiding the notification enough? Go into notifications in your Taskbar, find the one (s) that annoy you, and select do not show notifications.
