AOC 24" LED VS SAMSUNG 24" LED Help
282 (0.07/day)
Norway, North trondelag.
System Name Mats.
Processor Intel Core i7-6700K Skylake 4.0 ghz
Motherboard ASUS ROG MAXIMUS VIII HERO, Socket-1151
Cooling Corsair Hydro H100i GTX CPU Kjøler
Memory Corsair Vengeance LPX DDR4 2666MHz 16GB
Video Card(s) XFX Radeon R9 270X 2GB GDDR5 / Looking for upgrade
Storage Crucial BX100 250GB 2.5” SSD/ Western digital 250gb / ST 250gb / Westert digital 1tb
Display(s) AOC 24" LED G2460PQU
Case Corsair Carbide Air 540 Cube Case Hvit
Power Supply Cooler Master B600 VER.2, 600W PSU
Mouse Microsoft Intelli 3.0
Keyboard Microsoft wireless
Software Windows 7 64bit
Benchmark Scores DONO
Depends on how far back you can sid from your desk.
Key
samsung is 5ms, and the aoc is 1ms, would i notice the diffrence ?
Not really. Youd notice if it was 1/5 vs 15-25.
The aocs from personal experience Have been cheaply made and would fail between 1-3 years of use. Id go samsung, acer, asus
I would go for the Samsung, PLS is almost like IPS and the AOC looks to be a TN panel. I have a S24D590 and its fantastic.
AOC is good value. Samsung is a better panel.
I kind of dislike Samsung... just like smell of tobacco... but it is obviously better... hands down.
Samsung. /end
My oldest Samsung TV is 8 years old and works like the day i brought it home. My other Samsung is going on 3 years old and it too looks and works as new.
Antar du er norsk siden du linker til komplett norge. Samsungen har et PLS panel som er som et IPS panel, mens AOCen bruker TN panel (innsysvnkinel på 170/160 grader og 1 ms er omtrent alltid TN paneler, komplett har bommet på spesifikasjonene)
Samsungen er en bedre skerm som også er billigere, enkelt valg.
24" virker kasnsje stort til å starte med, men det er veldig godt å bruke, har selv en 30" og skulle ønske den var litt større her.
English:
Assuming you are Norwegian since you link to Komplett Norge. the Sasmung has a PLS panel that is as a IPS panel, while the AOC uses a TN panel (viewing angle 170/160 degrees and 1 ms are almost always TN panels)
The Sasmung is better and also cheaper, easy choice.
24" is not to big.
English:
24" is not to big.
Okei, takk :)
