Apacer DDR2 1066MHz 512MB/1GB Memory Modules
D_o_S
954 (0.13/day)
Processor AMD Opteron 144
Motherboard DFI Lanparty nF4 SLI-DR Expert
Cooling Watercooled - Alphacool Nexxxos XP, BIX2, Eheim HPPS
Memory 2x 512MB OCZ PC 3200EL Platinum Rev.2 (TCCD)
Video Card(s) 2x Gainward GeForce 6800 Ultra (430/1200)
Storage 4x WD Raptor 740GD in RAID 0
Display(s) Eizo FlexScan L768
Case CM Stacker
Audio Device(s) Audigy 2
Power Supply Silverstone Zeus ST65ZF
Taipei, Taiwan -- As the official memory supplier for the World Cyber Games 2006 (WCG2006) Grand Final, the world's largest PC and video gaming event, Apacer Technology Inc., a global leader in memory modules and digital storage, is releasing an Overclocking Series memory module that includes a DDR2 1066 MHz unbuffered 2 GB kit (1 GB x 2) and 1 GB kit (512 MB x 2). This new memory module satisfies the demanding performance requirements of cyber gamers, overclockers and enthusiasts pushing their platforms to the limit.
Apacer's Overclocking Series memory modules use only top-quality DRAM chips, which are specially supported by major IC manufactures. These top DRAM chips combine with Apacer's outstanding design, manufacturing and quality control and are tested to comply with the most rigorous dual-channel performance standards. All these efforts deliver cutting-edge Apacer Overclocking Series memory modules. To ensure dual channel performance and compatibility, Apacer's DDR2 1066 memory module comes in a 2 GB kit (1GB x 2) and a 1 GB kit (512MB x 2). Furthermore, Apacer's DDR2 1066 512MB memory module has been tested on Asus's P5B Deluxe motherboard with Intel P965 Express chipset and the result is that the preset 1.8V passed without needing to adjust the voltage. The DDR2 1066MHz 1GB was only adjusted to 2.0V. This ultimate performance means these new modules completely fulfill 3D gamers and overclockers extreme demands.
As PC performance increases, thermal management becomes increasingly important. When the operating temperature is lower, stability and reliability increase. Apacer adopts an oversized, high-performance, extruded aluminum heat sink in the module design. The functional matrix design cut into the surface contrasts nicely with the elegant green color to give a high quality look and feel. The unique U-shaped space increases heat dissipation area and allows gamers to add a fan on these memory modules.
According to Grace Lo, Senior Director of Apacer's DRAM department, the gaming and overclocking market will be Apacer's focus in the future. Apacer is developing new products that satisfy gamers' needs on performance and stability. She further adds that Apacer adopts the highest standards to design and produce Overclocking Series modules. From DRAM chip selection and testing, IC packaging, to actual testing on the most popular/mainstream motherboards ensures the best compatibility, reliability and stability. For example, Apacer insists module components are high-temperature tested at 80° C instead of normal 25° C testing. In addition, for each module, Apacer reserves a 5% safety margin that exceeds stated limits, and uses the specially designed aluminum heatsink to better handle thermal issues. All of these efforts are in place to 100% fulfill the high-standards gamers and overclockers need for new-generation hardware and applications.
For any questions on the new Apacer Overclocking Series DDR2 1066 1GB kit and 2 GB kit memory modules, check with your local Apacer sales channels.
About Apacer
Apacer Technology Inc. is a global leader in memory module and digital storage for both hardware and software research and development. Since the company's inception, Apacer's focus on recording, reproducing and retaining digital data of all kinds, allows our customers to "Access the best" memory products and services. Apacer is the fifth largest independent DRAM module supplier with a global sales and marketing network to support distributors, OEMs, and retail customers. Apacer has built a reputation for memory modules that offer high performance, reliability and value. Apacer also provides some of the newest and most exciting digital mobile entertainment devices that play, record, share and store the digital content that is part of everyday life. For more information about Apacer, please visit www.apacer.com.
