Application control error 1000 (0xc0000005 without crash)
Mercury98
15 (0.47/day)
The game called rocket league randomly writes this error code in the event log. Faultin module name: rocketleague.exe. No dll. So far I have only experienced this error in this game. I know that this error is some kind of access violation to the RAM. What is important is that the game does not crash.
The whole story is that the game is constantly changing, e.g. in speed, input, sometimes it is more graphically choppy (not microstutters). From that I think that these two things are connected, i.e. the error code and the change. I have tried a lot of things, I will detail them later, but right now I am thinking that this is not the problem, that I should restart the game many times, or maybe I should start a new epic games account. Or I even thought about superfetch. But if it still does not improve after these, then I think there is some special error between my computer and the game or I don't know. But I find it hard to believe this, because my old laptop also had similar problems in rocket league, but I did not look at the event viewer there. My old laptop was also ASUS.
PC specs:
-ASUS B660M Plus wifi d4 (newest BIOS 3801)
-I5-12400f
-DDR4 4000MHz Trident Z (from qvl list)
-Rtx 3070Ti
-750W Coolermaster MPE-7501-ACABW
-Kingston 1Tb ssd
-Windows 11 24H2
-Windows 10 I tried this too
-Dell G2723H
-Irid 503 argb V2: intel stock fan (cpu), 3 front and 1 back
So I think we can rule out some kind of software error, after I reinstalled Windows (clean) several times. Of course, as needed, the latest drivers from ASUS and offline installation (although with Windows 11 Home the internet is mandatory, I know there is a loophole, but it doesn't matter)
What I tried:
-Hardware tests such as: OCCT, Cinebench, Memtest86 (4/4 stage), Testmem5 (Anta777), FurMark... I didn't find anything strange here, no crashes or anything like that. So I think we can say that there is no hardware fault.
-Another RAM
-Another monitor (I know it has nothing to do with it but I really don't know what to do)
-Fast boot/fast startup disabled (I haven't disabled hibernation in Windows yet, but I've always done it. I just reinstalled Windows the other day to start with a clean slate)
-Clear CMOS
-A lot of software tweak I saw that can maybe cause a problem like this (game mode off and on, game bar off, power scheme high performance)
-At least 3 different Nvidia drivers (The latest ones are 566.36)
-The nvidia control panel 3d manage settings settings (Although I don't think these have anything to do with the problem)
-Windows defender firewall off
-Realtime protection off
-HPET off
-H.A.G.S off-on
-Clean Boot
-I've talked to Nvidia, Epic games, Microsoft, ASUS customer service
-GEN 4 PCIE to GEN 3 in BIOS (Now I use GEN 4)
-Run the game as administrator, disable fullscreen optimiaztion
-And many more which I can't think of right now, but if I do I'll expand the list
-LatencyMon (hard pagefile report in rocket league 20250 piece, when I started the game once. I think that's why I got the error, but I tried pagfile off and pagefile manual didn't work.
Also, many people have no problems with the game and my computer is perfect for running Rocket League. Also, what always comes to mind is that if no one else has such a problem with it, then it can't work (I'm thinking of superfetch off, for example). If no one else has a problem with it, then I shouldn't have one either. I know that every system is different, but still. I can only really look for the fault in myself, but I also find it hard to believe that if I restart the game and my computer several times as a test, the game should crash so much. I also know about that certain Heavy Car Bug in Rocket League, but I don't think that's it, because I don't only have a problem with input lag. I've already posted a lot about this, but I don't know how to delete the old ones and I think I described the problem best here.
Sorry that the picture is in Hungarian, but I think it's still understandable and I don't need to translate it into English because of that.
Thank you for reading!
Just fixed a similar issue. Finally fixed it by using DDU to uninstall Nvidia drivers using safe mode and turning off my network when reinstalling. Hope it works!
Where are you getting your windows installers from? Sounds potentially like a custom install that has a bunch of stuff screwed up from the start.
What all software do you have installed? Asus armoury crate or any third party stuff besides windows and drivers?
be more specific please. 3 isn't what i would call a lot.
any funky dll injection you aren't telling us about?
Power supply isn't what i would call a good one. What do voltages look like under all that testing load?
try memory at default speed.
sfc and dism and chkdsk all clean? what does ssd health look like?
0xc0000005 is almost always access violation.
I downloaded Windows from Microsoft site (mediacreationtool) to an USB.
I don't donwload any of these malware programs like AIsuite3 or Armoury crate etc. I just downloaded Epic games, Steam, EA app, some games. And directx runtime, visual c++ x64, x86 from 2010 to 2015-2022. That's all.
Haha,I know 3 not too much, but I wrote about these a little further down and thought of these tricks like H.A.G.S on-off, windowed games optimization on-off, disable fullscreen optimization, run as administrator.
I didn't do anything in regedit if that's what you're thinking. But as I mentioned, I just did a completely new Windows installation again, as written in the big book. After installing Windows, I updated Windows and then downloaded all the drivers. But I tried the other way around and that didn't work either. Sooner or later, the application error problem always comes up. That's why I think the problem is me (I restart a lot or something).
I'm not sure I understand what .dll you're talking about. But I thought that the Faulting module name only says rocketleague.exe and not some .dll or something similar.
I didn't check the voltages, just that the power supply can supply 100% of all units (GPU, CPU, etc.) under full load. How can I check the voltages?
I'm not using XMP right now, because of this error. But I've tried with and without XMP.
CrystalDiskInfo shows 98% good. Oh yeah, I forgot about that too, I've already tried sfc and dism, but they didn't find any corrupt files.
Yes, I read that, but I just can't figure out the cause of the problem. You mentioned the power supply, but what's strange to me about that is that it would only have this problem in this one game, which isn't very demanding?
Use HWinfo while doing all that load testing, it will show you voltages, temps, current, etc. Not a perfect diagnostic tool (before someone barks at me) but it is a good place to start.
Since I totally don't understand what should be how much, I took a picture. I know my CPU only used 65W, but I know this one POWER test in OCCT. But if you know a better one, please write it down. In the picture, what you can't see is my motherboard's voltages, which were below specification. Sorry for this many picture. BTW I found out OCCT shows voltage too, so 2 picture from OCCT. 1000106422.jpg1000106420.jpg1000106421.jpg1000106419.jpgThis image was under my motherboard specs1000106424.jpg1000106418.jpg1000106423.jpg
You can use Snipping Tool or just hit Win key + Print Screen to make a screenshot :) They will be save in Pictures/Screenshots.
I suspect it's a software bug, just like the Cyberpunk 2077 launcher.
I also suspect Windows logs the same code when I quit GTA V Enhanced.
I tried ti use DDU more times when I downloaded another nvidia driver just for test.
I thought about that too, but then why would this only happen to me? Because someone else wrote that there is no such error code. Also, I will update what I forgot (latencymon test).
I dunno.
Memory access violations absolutely exist.
Guys do you think if I replace my GPU it will be good?
I think it’s a red herring and you are in the weeds now.
Your game might run like trash and replacing the GPU might help but there isn’t any amount of money that would convince me it is the problem.
The world is a scary place when you look at the logs, and violations and failed to starts and all kinds of other problems happen all the time.
I thought about AMD GPU too. And the game is actually changing, so it's not just this error message that's the problem. I don't really play other games, and not much. So it would be worth it for me to sell my current video card and buy an AMD, NVidia card that can solve the problem, which is of the same value.
Obviously I know it's not a GPU problem because I don't get this problem in any other game. So it's some kind of driver or something, I don't know what it is. But I'm fed up with it, it's been like this for 2 years. Or some kind of incompatibility error, because if anyone else had such problems, it would definitely be a driver or BIOS error, but no one else has such a problem, this is my problem. I'm completely at a loss now.
Or maybe it's my ASUS motherboard, because my old laptop was ASUS too. It was bad there too, just don't if I got the same error there too.
