- Oct 9, 2007
- 47,949 (7.37/day)
- Dublin, Ireland
System Name | RBMK-1000 |
Memory | 2x 16GB DDR4-3200 |
Storage | Samsung 990 1TB |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
The new P12 Pro premium series from ARCTIC is complete: The 120 mm fan models are now available in all variants - including PST, A-RGB, White and CO. With maximum efficiency in terms of airflow and static pressure, the fans set new standards. The P12 Pro fans have been specially developed for applications with high air resistance. They are the ideal choice for demanding applications such as radiators and airflow-optimized PC cases.
Thanks to consistent engineering work - a revised fan blade design, an improved bearing, an automated measuring and balancing process and a new controller-motor combination - they enable maximum cooling performance with minimum noise levels. The entire P12 Pro Fan Series is now available at a discount of up to 50 % in the ARCTIC Webshop—the discount will be applied automatically at checkout. The series is also available on Amazon, eBay, and from select partners.
