ARK MKII
48 (0.01/day)
System Name Ikem
Processor AMD Phenom II x4 920
Motherboard ASUS
Cooling Xigmatek
Memory 2x2gb Crucial Ballistix Tracer DDR2 800
Video Card(s) EVGA Geforce 9800gtx+
Storage WD 750gb Black
Display(s) HP 1600x900 20 inch LCD
Case Lian Li
Audio Device(s) intergrated
Power Supply PC Power and Cooling 680watt
Software Windows 7
Benchmark Scores Stock: 2.8 GHz Mark1: 3.81 GHz
The old case mod can be found here: http://www.techpowerup.com/forums/threads/serene.174774/
ARK (not the boat, but known for Eternal Darkness)
This time I would like to add some water into the mix. The case was designed for water in mind, since I got it back in 2011, but I have never had the time or money to do it. Well an opportunity came buy and I decided to finish it.
Here is the OCN build log with some more pictures.
Specs are:
Dual Intel Xeon E5-2650 16core/32thread
ASUS Z9PE-D8
8x2gb Crucial Tactical Tracer 1600
Dual MSI HD 7870 Hawk Edition
Crucial M4 64GB OS Drive
Kingston HyperX 120GB Games Drive
10TB of Storage.
Cooler Master Silent Pro Hybrid 850w
Scythe Kaze Fan controller
XSPC EX360 Crossflow
XSPC Single DDC Res
DDC Pump
Phobya 1/2x5/8 Compression Fittings
1/2x5/8 Durelene Tubing
Dual EK Supereme HF CPU Blocks with 2011 kit
Dual EK Supremecy VGA Bridge Editions with Dual Parallel Bridge
3x Cooler Master Blade Master Fans on Rad
1x Scythe Gentle Typhoon AP-15
1x Scythe Gentle Typhoon AP-29
Lutro0 Customs Telilos and Stiffline Sleeving
Bitspower 360 Rad Grill
Lian Li v1200b
Here is a before pic:
Here is the bare bones CPU loop before filling. The Res as been modified a bit. The internal tube has been taken out, and the old fill port has been sealed, with a new fill power drilled and taped at the top.
The pumbing was routed to the angle in the Lian Li case, to make a nice clean entrance. The pump primes very fast, since the outlet is on the top.
This is how it is running right now. I didnt think that I was going to get GPU blocks, but did. Mayhems white with Blue die is the perfect combo.
I still have to re-sleeve the PSU, and finish the loop. Everything should be in this week. Here is how the sleeving is going to go.
Some other shots:
You can see the levels of the res from inside the case.
Sweet! Dual sockets are awesome.
can you play games with it?
if yes, is there a real gain in games that are cpu hungry?
I do play game, but use it mainly as a photoshop/vegas workstation.
Unless the game is insanely multithreaded, i dont really notice a difference. Since the cores only boost to 2.8ghz. Heck even some games wont run, unless I turn off hyperthreading.
polishing has started!
Cool looks great!
well after a little progress this weekend, my Lutro0 order didn't arrive so I couldn't finish the wiring.
i think everything is coming together. any recommendations? I am probably going to rename the build on completion too.
Routed some of the cables under and tucked them up nicely.
Started on the PCI-e power cables.
After I cut the chunk off the top, I had to make sure it was polished to the same degree as the other faces.
yes, it is flowing correctly... just looks weird since it is RATX.
Some Heatshrinkless sleeving done. Just have anouther 8 pin, 24 pin, and 2 6 pin pci-e to go.
