ASP.net C# web development?
Braveheart
1,115 (0.18/day)
System Name mystie
Processor intel Q9450
Motherboard gigabyte EP45 UD3P
Cooling coolit domino ALC
Memory 4GB DDR3 1333
Video Card(s) sapphire 4870x2
Storage 250GB barracuda, 1.5TB barracuda
Display(s) 15" phillips, HannsG HD 28"
Case custom built plexiglass cube
Audio Device(s) Creative audigy SE
Power Supply Silverstone Strider 700W
Software Vista home premium 64/ Ubuntu 10.04 Beta 64
anyone ever design a site with ASP.net C#?
yeah. why you ask?
Yeah. Why yoos wanna know?
Maybe $5 will refresh my memory...
...cause i know C# and im wanting to design a site and instead of learning HTML, java and CSS i wanted to know if i could just use C#...
I don't think your using the right part of your brain in this situation... try moving a wall instead.
ASP.NET is extremely HTML centric in terms of syntax and GUI design. Said another way: ASP.NET extends HTML. The C# code runs server side and is used to access databases and the like. The ASP code bridges the gap between HTML and C#.
You'll want to learn CSS too.
BTW, ASP.NET negates the necessity of learning JavaScript. Java applets really aren't that popular, nor is JSP.
ok...yeah i am finding that as i play with dreamweaver all i need to know is how to use the program, a little HTML and CSS...not sure whats the big deal with "Web designers"...seems just a little harder than screwing with photoshop all day :nutkick:
There's two types of web designers: those that know WYSIWYG and those that know the languages. The first uses Dreamweaver/Frontpage, the second favors Notepad, Editplus, and other text editors. I can't stand Dreamweaver/Frontpage because it makes a mess of the source code.
I agree.
im working on using notepad...in about 1 year i should be able to write programs and sites in notepad...just give me some time :)
The first time I used FP I looked at the source code and was stunned at the amount of crap that was added. Removing the bloat reduced the file size by about 2/3.
I usually use the VS IDE for all my coding needs, unless I just need to do some page updates in which case it's notepad for me too.
What do you all see as the best "beginner" IDE for basic webprogramming? Ie. to creative some mildy server side interactive webpage, not dead WYSIWYG pages.
Example:
A webpage to have a login, and depending on the user, it will direct the user to private pages.
So true :D
At my last job my boss thought that he could 'help' by working on the company's database-heavy internal site. He used Dreamweaver in Designer mode with the PHP MySQL server model while I used Dreamweaver solely in code view. His pages would sometimes take seconds to execute while I aimed for a tenth of a second or faster. I ened up re-writing his pages.
Example:
I like the "intellisense" feature of the VS IDE (Web Dev Express if the free version for web programming). I think it would be very useful for a beginner as it tells you all of the options you have for specific commands.
Example:
I would use EditPlus if it were coded in PHP and Visual Studio if it were coded in ASP.NET.
