ASRock Reveals AMD Radeon RX 9060 XT Series Graphics Cards
GFreeman
2,020 (2.39/day)
ASRock, the leading global motherboard, graphics card and mini PC manufacturer, today launched the new Steel Legend and Challenger series graphics cards based on the latest AMD Radeon RX 9060 XT GPU. As the latest member of the AMD Radeon RX 9000 series GPUs, AMD Radeon RX 9060 XT also uses the AMD RDNA 4 architecture, which is equipped with the 3rd Gen ray tracing and 2nd Gen AI accelerators, provides up to 32 AMD RDNA 4 compute units, and supports AMD HYPR-RX, AMD FidelityFX Super Resolution (FSR) 4 and advanced Frame Generation..., and other AMD's latest exclusive technologies, plus the latest specifications such as DisplayPort 2.1a, PCI Express 5.0, and also a large-capacity up to 16 GB GDDR6 memory. These rich features and specifications provide end users with an excellent AAA gaming experience.
Otherwise, ASRock AMD Radeon RX 9060 XT Series graphics cards also support various ASRock exclusive features, including the Striped Ring/Axial Fan, Air Deflecting Fin, Ultra-fit Heatpipe, Metal Backplate, and Polychrome SYNC technology to provide great cooling efficiency, solid construction and fancy ARGB lighting effects. With these exclusive features, ASRock AMD Radeon RX 9060 XT Series graphics cards are premium choices for gamers and system integrators.
ASRock AMD Radeon RX 9060 XT Steel Legend 16 GB OC Graphics Card and ASRock AMD Radeon RX 9060 XT Steel Legend 8 GB OC Graphics Card
ASRock AMD Radeon RX 9060 XT Steel Legend 16 GB OC and ASRock AMD Radeon RX 9060 XT Steel Legend 8 GB OC graphics cards for white-themed PC builders achieve a Boost Clock of up to 3320 MHz. The triple-fan thermal design with the unique Striped Axial Fans, Air Deflecting Fin and Ultra-fit Heatpipe provide excellent heat dissipation. The metal backplate strengthens the structure and prevents the plate from bending. The ARGB LED panel and ARGB fans combined with Polychrome SYNC software allow users to customize and control the lighting effects. With these useful features, unique white-themed outlook along with factory pre-overclocking, ASRock AMD Radeon RX 9060 XT Steel Legend 16 GB OC and ASRock AMD Radeon RX 9060 XT Steel Legend 8 GB OC graphics cards are designed for visually appealing white PC builds.
ASRock AMD Radeon RX 9060 XT Challenger 16 GB OC Graphics Card and ASRock AMD Radeon RX 9060 XT Challenger 8 GB OC Graphics Card
The mainstream ASRock AMD Radeon RX 9060 XT Challenger 16 GB OC and ASRock AMD Radeon RX 9060 XT Challenger 8 GB OC graphics cards offer a Boost Clock of up to 3290 MHz. It is equipped with a newly designed and stylish dual-fan cooler, the exclusive Striped Axial Fan, and Ultra-fit Heatpipe to provide efficient heat dissipation. The LED indicator makes the graphics cards more visually appealing. The metal backplate strengthens the structure, while the high-quality Super Alloy Graphics Card components provide more stable operation and the factory default overclocking settings deliver higher performance. These practical designs enable the ASRock AMD Radeon RX 9060 XT Challenger 16 GB OC and ASRock AMD Radeon RX 9060 XT Challenger 8 GB OC graphics cards to be essential for system integrators and mainstream users.
For more information, please visit:
@GFreeman
1st link of "For more information": "1 6GB"???
Typo?
To big, I hope they will show some small 9060 xt :)
Nice cards but I would really like to see a single fan model. It can be dual slot, that's fine but a SFF build would be awesome with one of these in a single fan form factor.
They really need to bring back the Nano models for these low end cards. Such a missed opportunity. Also everyone making oversized RGB coolers to justify bonkers over the MSRP prices...
