- May 12, 2006
- 1,616 (0.23/day)
- The Gulag Casino
System Name | ROG 9800X3d By purecain |
Processor | AMD Ryzen 7 9800X3D |
Motherboard | ASUS Crosshair X670E Hero |
Cooling | Noctua NH U12A |
Memory | 64Gb G.Skill Trident Z5 neo RGB 6400@6000mhz@1.41v |
Video Card(s) | Aorus RTX4090 Extreme Waterforce |
Storage | 990Pro2Tb-1TbSamsung Evo M.2/ 2TbSamsung QVO/ 1TbSamsung Evo780/ 120gbKingston Now |
Display(s) | LG 65UN85006LA 65" Smart 4K Ultra HD HDR LED TV |
Case | Thermaltake CoreX71 Limited Edition Etched Tempered Glass Door |
Audio Device(s) | On board/NIcomplete audio 6 |
Power Supply | Seasonic FOCUS 1000w 80+ |
Mouse | M65 RGB Elite |
Keyboard | K95 RGB Platinum |
Software | Windows11pro |
Benchmark Scores | [url=https://valid.x86.fr/gtle1y][img]https://valid.x86.fr/cache/banner/gtle1y-6.png[/img][/url] |
Own an AMD Ryzen CPU?
Want to run Assassins Creed Odyssey?
well i guarantee you will get crashes if your memory is not 100 percent stable. I've run some pretty big games on this pc with my old settings and never had a problem with any.
Until now. Assassins Creed Odyssey uses memory inefficiently. It stresses the CPU's Infinity Fabric.
I had to lower memory speed to 3400mhz and 1700mhz for the cpu infinity fabric to run without errors which led to a crash. This has fixed the game and i literally stream for hours np.
I also just attempted to carefully up the memory speed, and any setting above 3400mhz would crash the game after an hour or so.
You very likely don't need to reinstall or check the game files. or under clock your CPU. You do however have to keep this Infinity Fabric below 1700mhz or the CPU will not be able to cope. tested on rig in sig.
