- Sep 2, 2021
- 288 (0.21/day)
- Colorado
Processor | AMD Ryzen 9 9950X |
Motherboard | Asus ROG Crosshair X670E Gene |
Cooling | Full Custom Water |
Memory | G.SKILL F5-6000J2636G16GX2-TZ5NR |
Video Card(s) | XFX Mercury 9070 XT OC |
Storage | Crucial T700 2TB Gen5 SSD |
Display(s) | ASUS ROG Swift OLED PG27UCDM |
Case | BC1-V2 Titanium Edition |
Audio Device(s) | SteelSeries Arctis GameBuds |
Power Supply | SeaSonic Prime SSR-1300TR2 |
Mouse | Viper V3 Pro |
Keyboard | Keychron Q1 Max, Drop + Matt3o MT3 Susuwatari, Gateron Milky Yellow Pro. |
Software | Windows 11 Pro 24H2 |
Benchmark Scores | http://www.3dmark.com/pcm10b/2181791 |
Has anyone used Asus DIMM FIT, or DIMM FIT Pro,.. that can share some tips, or advice on best set-up for the Pro version.
I'm testing Asus DIMM FIT tonight,.. will test DIMM FIT Pro in the morning.
I used an Intel XMP 2x24GB 8000CL38 kit, not listed in QVL. They recommend using EXPO kits in the QVL for best results on AMD system.
I set DOCP 1 in bios then saved profile in store 0,.. then ran DIMM FIT, the results were very good, I was also able to load the profile to USB drive to save file after running tool.
I will post some results,.. after I figure out 100% how to use the tool. It's mostly trial & error for me on this first run, I had no clue it would take 5-hours to run.
