- Jul 18, 2007
- 813 (0.13/day)
- Almonte, Canada
System Name | Sonny Boy |
Processor | i5 11600K 4.9GHz @ 1.35 Vcore |
Motherboard | AORUS Z590 Elite AX |
Cooling | Deepcool Gammix 240mm AIO |
Memory | 4 X 8GB Teamgroup DDR4 3200MHz |
Video Card(s) | ASUS RTX 3060 Ti GDDR6X |
Storage | Adata Legend 1TB |
Display(s) | Philips 27" 4K |
Power Supply | Corsair 750W |
Mouse | Razer Basilisk |
Keyboard | Razer Huntsman V2 |
Software | Windows 11 Pro |
System Specs
i5 11600K running 4.9GHz all cores at 1.35V
AORUS Z590 Elite AX
32GB Teamgroup DDR4 3200MHZ
ASUS Dual RTX 3060 TI GDDR6X
Deepcool Gammix AIO 240mm CPU cooler with Arctic Cooling MX4 paste
Corsair 750W
I have had this ASUS Dual RTX 3060 TI GDDR6X card for a while and noticed that memory temps are higher than I would like given that Micron recommends junction temperature of 0-95C. With stock configuration and no overclock on memory I was routinely hitting 96C on the memory at 1440p or 4K gaming. The GPU core was hitting around 79C. Happy with CPU temps topping out at about 70C on the cores.
Despite being under warranty I decided to try bringing down the VRAM temps and maybe the GPU core as well. I started by ripping off the warranty tape on the screw and proceeded to disassemble the card. See photos. I measured all of the existing thermal pad thicknesses as I removed them (photos).
VRAM 2mm
VRM 2mm
Everything else on front of card 2mm
Backplate strips are 1mm
Owltree 12.8W/mK pads from Amazon. It comes with 0.5, 1, and 1.5mm sheets
Arctic Cooling MX6 thermal paste
I had to stack 1.5mm and 0.5mm strips to get the 2mm required thickness on the front.
Results were promising. I found worst case VRAM temps could be achieved running 3Dmark Speedway Ultra stress test. Fan curves were stock settings.
Stock max temps
79.0C GPU Core
96.0C VRAM
92.6C Hot Spot
Modded max temps
71.0C GPU Core -8.0C
92.0C VRAM -4.0C
86.4C Hot Spot. -6.2C
Was actually hoping for more improvement on VRAM temps but the stress test is worst case. Most games I am only hitting about 88-90C. Better than what I started with anyway.
AORUS Z590 Elite AX
Corsair 750W
VRAM 2mm
VRM 2mm
Stock max temps
79.0C GPU Core
96.0C VRAM
92.6C Hot Spot
Modded max temps
92.0C VRAM -4.0C
