ASUS Intros GeForce GTX 1060 3GB Phoenix Graphics Card
47,837 (7.39/day)
ASUS introduced the GeForce GTX 1060 3 GB Phoenix graphics card. Designed with low cost in mind, this card is 18.3 cm long, and combines a custom-design PCB that draws power from a single 6-pin PCIe power connector, with a simple monolithic aluminium fan-heatsink cooler. The heatsink features a copper core, which dissipates heat to an aluminium block with spirally projecting fins; which is ventilated by a single 80 mm dual ball bearing fan. The GPU is clocked at NVIDIA reference speeds of 1506 MHz core, 1708 MHz GPU Boost, and 8.00 GHz (GDDR5-effective) memory. As the 3 GB variant of the GTX 1060, the chip features just 1,152 CUDA cores. Display outputs include two each of DisplayPort and HDMI connectors, and a DVI port. ASUS didn't reveal pricing.
joke of a card, why they would still sell 3GB cards mid-2017? it's barely enough to play new games at medium settings, soon you'll have to lower them down to low, RX 470 4GB is by far a better choice
Isn't "Phoenix" branding already used by Gainward?
@microsista GTX 1060 3 Gb outperforms RX 470 4 Gb and even RX 480 4 Gb ;)
That isn't how it works.
As I know they do and as well I have GW 1070 Phoenix GS.
even NBA 2k17 eats up more than 3gb of vram
Uhmmm... I wouldn't be buying a new card on your advice..:rolleyes:
In today's world it's all about customization. 3GB may not be enough for you, but are plenty for people like me.
what i dont like is that they are not saying on box that it has less shaders+tmu´s.(but thats not asus alone-nvidia says what to and not )
for the not tech savvy it seems like only 3gb versus 6gb
Yeah okay. Didn't have any problems running ME: Catalyst with 2c/4t CPU, 8GB DDR4 & GTX780Ti 3GB @ 1080p Ultra.
You are saying that 3gb model card can not play any modern game on high at 1080p ? If it had 4gb then it could ? You know shit about this.
I wish they sell this sort of cards w/out plastic with smaller cooler if possible and in a stupid plastic bag w/out anything so i can pay 150 dollars for it. $200 is still too much for me.
Even a 2 Gb gpu can play @1080p )))) like electro has
looks like they are really trying to clear out the 960 strix PCBs, they already have a 1060 using that pcb with the strix dcu2 cooler and now this
Like this one?
