ASUS Intros ROG Swift PG27UQ Monitor with G-SYNC HDR
47,658 (7.43/day)
ASUS today introduced the Republic of Gamers (ROG) Swift PG27UQ, a 27-inch monitor with 4K Ultra HD resolution (3840 x 2160 pixels), a staggering 144 Hz refresh-rate, and support for NVIDIA G-Sync HDR. Under the hood is an IPS Quantum-Dot panel with DCI-P3 Color Gamut support, 4 ms response time, 178°/178° viewing angles, and 10-bpc (1.07 billion colors) support. 300-1000 cd/m² maximum brightness, and 20,000:1 static contrast ratio, make for the rest of the panel specifications.
The monitor features (and requires) DisplayPort 1.4 to sustain 4K @ 144 Hz with 10-bpc color. It also features HDMI 2.0. Also featured are GamePlus (OSD goodies), GameVisual (genre-specific display presets), a and 2-port USB 3.0 hub. The stand and the back-side of the display features RGB LED elements that can be controlled by Aura Sync RGB. The company didn't reveal pricing.
717 (0.26/day)
France
Processor RYZEN 7 5800X3D
Motherboard Aorus B-550I Pro AX
Cooling HEATKILLER IV PRO , EKWB Vector FTW3 3080/3090 , Barrow res + Xylem DDC 4.2, SE 240 + Dabel 20b 240
Memory Viper Steel 4000 PVS416G400C6K
Video Card(s) EVGA 3080Ti FTW3
Storage XPG SX8200 Pro 512 GB NVMe + Samsung 980 1TB
Display(s) ROG Strix OLED XG27AQDMG
Case NR 200
Power Supply CORSAIR SF750
Mouse Logitech G PRO
Keyboard Meletrix Zoom 75 GT Silver
Software Windows 11 22H2
In case you wonder about the price : 2500€ here in France !
It almost makes the Acer one look dirty cheap :roll::roll::roll::roll::roll::roll::roll:
7,013 (1.41/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
Go for 21:9 people. You don't know what you are missing... ;)
18,456 (2.47/day)
1,180 (0.19/day)
Australia
Processor Intel i7 4790K
Motherboard Asus Z97 Deluxe
Video Card(s) Asus R290X
Display(s) Samsung S23A950D
Case Corsair 850D
Power Supply Corsair AX850
Keyboard Logitech G710+
Is this the first flat quantum dot monitor? It looks flat in the pictures.
1,503 (0.37/day)
Processor 11900K
Motherboard ASRock Z590 OC Formula
Cooling Noctua NH-D15 using 2x140mm 3000RPM industrial Noctuas
Memory G. Skill Trident Z 2x16GB 3600MHz
Video Card(s) eVGA RTX 3090 FTW3
Storage 2TB Crucial P5 Plus
Display(s) 1st: LG GR83Q-B 1440p 27in 240Hz / 2nd: Lenovo y27g 1080p 27in 144Hz
Case Lian Li Lancool MESH II RGB (I removed the RGB)
Power Supply Seasonic Prime 850 TX
Mouse Glorious Model D
Keyboard Glorious MMK2 65% Lynx MX switches
Software Win10 Pro
I know in HDR 4:4:4 the max refresh is 98Hz. What is the max refresh without compression for 4:2:0 on DP 1.4?
4 (0.00/day)
HDR on or off doesn't require more bandwidth - the limitation is with 8-bit vs 10-bit colour. It should be able to do:
8-bit full range RGB at 144 Hz
8-bit limited range YCbCr444 at 144 Hz
10-bit limited range YCbCr422 at 144 Hz
10-bit limited range YCbBr444 at 98 Hz.
8-bit full range RGB is not equivalent to 8-bit limited range YCbCr444. YCbCr is always limited range which looks like crap at 8-bit. Limited range is a non-issue at 10-bit, but 4:2:2 makes the desktop unusable.
It does 144 Hz without compression (DSC) due to overclocking. 4:2:2 is not "compression".
1,227 (0.48/day)
Processor AMD Ryzen 9 5950X
Case Cooler Master Cosmos
Power Supply Corsair HX850i
Keyboard Cherry MX
Now this is a nice monitor, but priced crazy so only the top end money wasters can afford it... Shame. I would like a non nVidia version of this, with a lower price point.
Fx
1,332 (0.22/day)
Portland, OR
Processor Ryzen 2600x
Cooling Noctua
Video Card(s) EVGA 980ti FTW
Case Fractal Design Define R5
Mouse Mionix Castor
Keyboard Deck Hassium Pro
These specs are what I have been waiting years for, but I can't see myself ever spending more than $1,000 for a <27" monitor. I don't care how good it is.
So next thought... how long do I have to wait for the price to come down to a practical range?
470 (0.12/day)
System Name Desktop / "Console"
Processor Ryzen 9800X3D / Ryzen 5800X
Motherboard Asus Proart X870E / Asus X570-i
Cooling EK AIO Elite 280 / Cryorig C1
Memory 64GB Corsair Vengeance DDR5-6000 CL30 / 16GB Crucial Ballistix DDR4-3600 CL16
Video Card(s) RTX 5090 FE / RTX 4090 FE
Storage 1TB Samsung 980 Pro, 1TB Sabrent Rocket 4 Plus NVME / 1TB Sabrent Rocket 4 NVME, 1TB Intel 660P
Display(s) Alienware AW3423DW / LG 65CX Oled
Case Lian Li O11 Mini / Fractal Ridge
Audio Device(s) Sony AVR, SVS speakers & subs / Marantz AVR, SVS speakers & subs
Power Supply ROG Loki 1000 / ROG Loki 1000
VR HMD Quest 3
the 21:9 version of this monitor is PG35VQ, (though it is 1440p instead of 4k) --- and I will be making that leap.
717 (0.26/day)
France
Case NR 200
I would say probably in 3yrs you will find those kind of specs at 1K or even below that ......
688 (0.23/day)
Samsung is updating firmwares of some of their 2018 TVs. The 65" version of the NU8000 costs 500$ less than this 27" G-Sync "wonder" while the 75" version costs 500$ more. No comment
3,881 (0.82/day)
The new firmware introduces FreeSync support to some of their lineup. Its also just 1080p support at the moment. Aimed at consoles user as a added value to the TV.
Digital Trends said:
Although Samsung does sell FreeSync TVs, they are not something its entire range typically supports. As of firmware update 1103 though, it appears that more of its lineup than ever can now make use of it. According to Rtings, Samsung’s QLED Q6FN, Q7FN, Q8FN, Q9FN, and NU8000 all now support FreeSync technology. If you have your AMD graphics-equipped PC or an Xbox One S or X hooked up to one of those TVs, you should now be able to enjoy FreeSync.
To make use of the new FreeSync mode, you’ll need to head into the TV’s settings menu, followed by General, External Device Manager, Game Mode Settings and ultimately, select “FreeSync.” Set it to “On.” Options include “Ultimate,” which has a range of 48-120Hz, while “Basic,” supports 90-120Hz.
Gaming on your couch or bed watching a 55-65-75-82 inch screen on your X-Box is not bad,
688 (0.23/day)
And the later ones will get higher resolution. They need to start somewhere. And that's a big selling point.
1,164 (0.20/day)
Chicago, Illinois
By the time they reach a price you're willing to pay you'll likely be dead.
Playing Shadow Of War and Witcher3 on the couch with my lapboard was pretty awesome. Next time I get to play a game will be better with my recliner :)
