g12rxz
- Apr 9, 2006
- 293 (0.04/day)
- Illinois
Processor | AMD Athlon64 X2 4200+ @ 2.6ghz |
Motherboard | ECS KA3 MVP Crossfire 3200 Chipset |
Cooling | None to speak of. |
Memory | 2048MB DDR2 Patriot Memory 4-4-4-12 |
Video Card(s) | X1800GTO2 512MB soon I'll flash to an XT! |
Storage | 250GB 7200RPM 16MB Cache SATA Seagate |
Display(s) | 19 inch widescreen 4ms by AG Neovo |
Case | Gigabyte Poseidon Mid-Tower ( AWESOME CASE! ) |
Audio Device(s) | Sound Blaster Audigy 2 Platinum -- 200 Watts to each Jamo Classic 10, powered by a Denon Class A amp |
Power Supply | Rosewill 600Watt w/ Active PFC and Dual +12v |
Software | Windows XP Professional SP2 |
I received the ASUS M2N-E to replace my ECS KA3 MVP today, hooked it up and booted up the computer. I installed all the latest drivers, but there are a few oddity's. Currenlty my hard drive is showing up as a 'removable device' and i have the removable device icon in my taskbar, but this cant be right because its my internal SATA3gbs HD! Also, in device manager i have an 'unknown pci device', and even after all the driver installs... it still hasn't gone away. I'm curios if it has to do with the ATI Catalyst drivers... will be checking that for any conflicts, but i would also like any help you guys can offer! Another thing is i can't overclock at all... wondering if its my bios, a new revision is out, but i dont know what mine is, and they say not to use the EZ-Flash utility so now i have to figure out how to flash the bios....
UPDATE
Removed all forms of ATI drivers, restarted, reinstalled catalyst 6.8's
Figured out why the hard drive shows up as a removable device, not worried
device manager still shows an uknown pci device (code 28)
UPDATE
