Hi, I'm having trouble with a new mobo I switched to.
There's currently 3 HDDs and a Samsung DVD burner installed but I can't boot up using the DVD burner. I was even having trouble with the boot priority but maybe it's better now. I like the layout of the Asus BIOS (I guess it's American Megatrends?) but it's weird, but sometimes it seems like changes aren't taken into effect. Also, I'm not sure how to use the SATA drives in SATA mode but I think I just need to enable AHCI mode?
I don't think the DVD burner is even enabled or detected. I had a Gigabyte P35 board previously and the BIOS was so easy but maybe not laid out as well. I was just so used to it, though, and at least, everything worked.
I'm not sure what's wrong so I hope some experts out there can identify or recognize what's going on! :-(
I tried a Linux LiveCD and it doesn't boot up. I then tried booting into a Linux distro on the HDD and the DVD optical drive is not detected.
I can't do much with Windows at the moment since the ethernet hardware isn't working properly, which I assume, is the result of the mobo change. I think I might temporarily solve this by installing drivers from the Asus CD? I'm planning on a re-install of everything but I need the DVD drive to be detected and work, first. :-/
Anybody have an idea what's wrong?
