- Jun 20, 2007
- 3,942 (0.60/day)
System Name | Widow |
Processor | Ryzen 7600x |
Motherboard | AsRock B650 HDVM.2 |
Cooling | CPU : Corsair Hydro XC7 }{ GPU: EK FC 1080 via Magicool 360 III PRO > Photon 170 (D5) |
Memory | 32GB Gskill Flare X5 |
Video Card(s) | GTX 1080 TI |
Storage | Samsung 9series NVM 2TB and Rust |
Display(s) | Predator X34P/Tempest X270OC @ 120hz / LG W3000h |
Case | Fractal Define S [Antec Skeleton hanging in hall of fame] |
Audio Device(s) | Asus Xonar Xense with AKG K612 cans on Monacor SA-100 |
Power Supply | Seasonic X-850 |
Mouse | Razer Naga 2014 |
Software | Windows 11 Pro |
Benchmark Scores | FFXIV ARR Benchmark 12,883 on i7 2600k 15,098 on AM5 7600x |
EDIT: Board does not support 12v over eSataP.
P8 P67 Pro has two rear eSata connectors, one red (data only), one green (data/power).
I recently picked up one of these HDD SATA 22 Pin to eSATA Data + USB Power Cable.
Upon plugging it in, the hard disk is not powering on. I tried three different disks.
I have used every combination of red and green Esata ports with or without the accompanying USB lead.
Also plugged in the USB lead alone, to see if that would force power into the device.
I did this each time with the computer off first, to avoid any hotplug issues.
Furthermore I have the most recent eSata supported JMicron driver enabled in bios and the JMBX 36 driver installed in Windows.
Any ideas why it won't power on?
