ASUS Z97-A and 4790K Overclocking - *Dynamic* CPU Core Multi + Core Voltage ?
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
This is a blast from the past... I'm hoping someone here has a good memory or some recent experience. Sooo, I've got an i7-4790K, and just moved it from an MSI Z97 U3 (it's now dead) ....to an ASUS Z97-A motherboard
My goal is a good stable overclock with CPU clocks using speedstep and adaptive VCore voltages. On the MSI, this was was easy... I set the max CPU core ratio of 47 (all cores) and adaptive Vcore offset of +0.04v. When I loaded the system using AIDA64, the CPU clocks would jump from 800MHz to 4700Mhz and the voltage would jump from 1.181v to 1.224v. When I stop AIDA64, the clocks would return to 800MHz and voltage to 1.181v in idle.
On the ASUS, the CPU clocks are stuck at 4700Mhz and the voltage stays put at 1.200v. That's under load or idle. Speedstep is Enabled. What is the trick to get adaptive CPU core speeds and voltages?
Side observation: The ASUS BIOS is so much more complicated than the MSI was. Plus there are hardware switches that the BIOS manual does a crappy job of explaining, I haven't messed with them, it's not clear in the manual if the switches override the BIOS settings. This thing is driving me crazy.
Deleted member 185158
It may be from hot swapping the OS drive without uninstalling MSI drivers and software.
Basically if c-states are enabled, the cpu should use all the power states.
I'd try a fresh install of windows and motherboard drivers and see if that helps.
1,070 (0.55/day)
Have a 4790k in Gigabyte Z97 that uses C states fine. That is golden if those volts are accurate. Need 1.35 on mine for 4700.
Check your bios settings, windows power plan settings.
Maybe you fixed CPU multi at 47 instead of editing only the boost clock to ?
140 (0.03/day)
Ukiah
System Name The Tempest
Processor i7 5960x Haswell-E @4.5ghz 1.26 bios vcore 3.4ghz cache 1.175v on custom water 1.86vin llc default 5
Motherboard Asrock X99X Killer Fatality
Cooling Swiftech DDC mcp50-x pump XSPC RaystormPro waterblock Acool xt45 Supernova1260 rad 9 140mmfans 1vrmF
Memory 32gb 4x8gb Kingston HyperX Fury (Micron rev.b) 2400mhz 15-15-15-35 @ 3200 16-19-19-36 2T 1.41v
Video Card(s) AMD 6800 XT reference OC 2550~2650 1.13v mem oc 2150 Fast timing Alphacool Eisblock gpx waterblock
Storage M.2 2 TB SSD Seagate 4tb 5400 Western Digital 6tb 7200
Display(s) 4k HDR TLC 43" 60hz TV
Case Antec 900 Top fan 200mm/1side/2front/1rear 120mm AC Supernova 1260 rad 9/140mm fans 1700RPM 1VRM fan
Audio Device(s) Onboard Realtech Logitech 5.1 surround/ Bluetooth headphones
Power Supply Corsair RM1000i PSU
Mouse Logitech
Keyboard Logitech
Benchmark Scores Time Spy ~20000 Extreme 7800 Fire Strike 55000 Extreme 27415 Ultra 13604 Port Royal 10032
I have the Asus z97 pro wifi ac motherboard with that cpu. You need to have c-states in the adv cpu options page set to auto or enabled and in windows the minimum cpu usage set to 5%. Dynamic sets the ring or cache bus to 4.4 and all cores also. You want manual x47 also ring or cache needs to be set at minimum 8x for speedstep to work.
On my board although I set manual voltage for the cpu, I turn on c-states and speedstep to lower voltage at idle. If you have adaptive voltage turned on it lowers the volts even more.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Display(s) DELL U2311H
Keyboard Microsoft Wired 600
My goal is a good stable overclock ..............
Wrong choice of a motherboard, if you plan wild acrobatics.
For 4790K at stock, it will do the job.
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
The SSD I'm using for the ASUS never saw the MSI. But, I do have a spare SSD and could give it a try.
This one is doing great with 1.224v @4.7. No throttling, temps now peak in the low 90s. Keeps going down with the paste setting in. I was doing 4.8 at 1.34v, but throttling.
There's only one place that I can see to set the peak multiplier, I've got it set to "All cores" and 47. Is there another place to look?
Interesting, I'll have to look at the cache setting. I may be sending you a PM :) The package only pulls 11 watts idle, so something is going right even if the multi isn't dropping. Any I do have the voltage set to adaptive+offset.
This chip +MB got to 4.8 at 1.34v, with air cooling (Scythe Ashura), a few cores were throttling. It's golden at 4.7 and 1.224v
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Your Long Service badge, this is should translate, that you are AWARE that 4790K pushed to the end of the road = 6 FPS more than my 4770 with OCed BUS 2400 with the blessings of INTEL Corporation.
My advice, waste your productivity in to something else.
8,319 (5.24/day)
São Paulo, Brazil
Cooling Pichau Lunara ARGB 360 + Honeywell PTM7950
Memory 32 GB G.Skill Trident Z5 RGB @ 7600 MT/s
Video Card(s) Palit GameRock GeForce RTX 5090 32 GB
Storage 500 GB WD Black SN750 + 4x 300 GB WD VelociRaptor WD3000HLFS HDDs
Display(s) 55-inch LG G3 OLED
Case Cooler Master MasterFrame 700 benchtable
Mouse Microsoft Classic IntelliMouse
Software Windows 10 Pro 22H2
To address your initial question: disable ASUS Multicore Enhancement feature in the AI Tweaker section of the BIOS if you haven't already. This is likely what's causing your CPU to run the 1C turbo boost tables on all of the four cores.
Regarding the 4.8+ GHz OC: I would tend to agree with @kiriakost, the 4.7 GHz @ 1.225V setting seems reasonable enough for this processor, if it can hold that through say, AVX workloads. Gains, if any, will likely not be meaningful against the sheer amount of time you would spend re-tweaking and optimizing everything again.
It's a decade-old quad-core processor, unless the objective is to shatter some vintage benchmarks, it's not worth bothering with trying to push it to the absolute edge any longer, especially if your motherboard is on the lesser end. Seems like a lot more trouble than it's worth to me.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
This is no voting thread.
This platform can do at 1080P 90FPS, and if you are talented at first person shooter, youth owns RTX3080 will be full of tears. :)
Gaming its totally enjoyable, and there is no productivity software that will not feel Snappy, if you are using quality HDD.
If the older quads had AVX, they would be still a good choice.
But I have to admit that having faster SATA controller Z87X and later, this makes SSD to deliver remarkable and respectable bandwidth.
Conclusion:
1) Snappy gaming
2) Snappy productivity
3) Super fast SATA controller, 560MB Read/ Write.
= There is no chance for me to feel that I am driving any antique car ;)
1,712 (1.04/day)
Tel Fyr
System Name 1️Purple Haze 2️Vacuum Box
Processor 1️AMD Ryzen 7 5800X3D (-30 CO) 2️Intel Xeon E3-1241 v3
Motherboard 1️MSI B450 Tomahawk Max 2️Gigabyte GA-Z87X-UD5H
Cooling 1️Dark Rock 4 Pro, P14, P12, T30 case fans 2️212 Evo & P12 PWM PST x2, Arctic P14 & P12 case fans
Memory 1️32GB Ballistix (Micron E 19nm) CL16 @3733MHz 2️32GB HyperX Beast 2400MHz (XMP)
Video Card(s) 1️6900XTXH ASRock OC Formula LM'd & Phanteks T30x3 2️5700XT Sapphire Nitro+ LM'd & Arctic P12x2
Storage 1️ADATA SX8200 Pro 1TB, Toshiba P300 3TB x2 2️Kingston A400 120GB, Fanxiang S500 Pro 256GB
Case 1️Modded MS Industrial Titan II Pro RGB 2️Heavily Modded Cooler Master Q500L
Power Supply 1️Rosewill Capstone 1000M 2️Enermax Revolution X't 730W (both with P14 fans)
This may sound rude, but why is it so important to have that downclock to 800MHz, and the difference in voltage of 0.019V? This coming from a static OC forever guy's perspective, so I'm just curious. I won't mind if you ignore my question, it's almost rhetorical anyway.
1,070 (0.55/day)
4790k has AVX2. Interestingly it gets higher score in the CPU Z AVX benchmark than the standard one. My Ryzen machine is the opposite.
Not found a reason to upgrade, yet.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
All Haswell family has AVX2 enabled, at old 3Dmark 11 there is under evaluation the parameter named as Physics Score.
Physics Score = combination of how fast GPU along CPU, they can render 3D environment ( mountains, trees, walls, anything that surrounds the player).
At this parameter alone, Haswell due the AVX2 support it gives double the money VS older Quad core Q9650.
I was unaware that most recent game engines they are so much AVX2 dependent, identical GPU with Haswell = double frame rate at Battlefield V.
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
The Multicore Enhancement is something I'll check, thanks.
The 4.8 was surprising. Yes, there's a point of diminishing returns... and one of the reasons I don't do water-cooling anymore. Overclocking has been part of my PC enthusiasm for decades, so at some point it's more for entertainment than purpose ;) I'm happy with 4.7Ghz.
As I mentioned above, power use drops to 11W when idle (even with cores at 4700). My desire to have clocks drop to 800 in idle is simply because... it should. If I can't find a simple resolution, so be it.
Yes. Coupled with an aging Vega 64, I can play games on a 1440p monitor just fine (at least most). Other than that, it's not used for any other heavy tasks, so I'm quite happy with the performance. This will get me through the year and next winter is my planned upgrade cycle.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
True when CPU this set at default clocks and only at default.
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
On the two MSI Z97 boards I was working with, they ramped up to 4700 under load and back down to 800 in idle. Same with voltage.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
And now they are dead?
