ATI Catalyst 9.10 BETA
10TaTioN
257 (0.04/day)
Portugal
Processor Intel Core 2 Duo Q9550 @ 3.833Ghz [Stable]
Motherboard ASUS P5Q Pro
Cooling Xigmatek HDT-S1283
Memory Team Group DDR2 Xtreem Dark PC2-8500 @ 902Mhz
Video Card(s) PNY GTX 570
Storage Western Digital 1TB WD10EARS
Case AeroCool AeroEngine II
Software Windows 7 x64 RTM
Benchmark Scores http://valid.canardpc.com/show_oc.php?id=754350
ATI Catalyst 9.10 BETA (RC7)
If you bought a new Radeon 5800 Series (or you're waiting for yours to get home) and you're using Vista/7 this is for you.
ATI Radeon HD 5800 series recommended graphics driver
This driver is recommended for all users using the ATI Radeon™ HD5870 series and/or the ATI Radeon™ HD5850 series using Windows Vista and/or Windows 7
Applicable Products:
The issue applies to the following products:
* Graphics Cards:
* Operating System:
Windows Vista 32-bit Edition
Windows Vista 64-bit Edition
Windows 7 32-bit Edition
Windows 7 64-bit Edition
Download here:
http://support.amd.com/us/kbarticles/Pages/ATIRadeonHD5800seriesrecommendedgraphicsdriver.aspx
Updated BETA (RC7)
If you managed to buy one on the first day that is!
So what version comes in the box then?
Probably 9.9 or an Alpha version of 9.10, otherwise they wouldn't release a new one, i think. :/
isnt there a driver included on the now old CD :P that nobody uses hehe
btw i looked at .inf files and they said the driver also supports HD 4000 series
btw i dont think they release a alpha driver with the cards, you know alpha is HORRIBLE unstable hehe, beta is more like stable
Does this driver version support Eyefinity?
Just installed Sapphire HD 5870 and 2 DVI connected 22" LCD monitors and another on the way for tomorrow.
I do not see any Eyefinity Tabs or options in CCC which I just downloaded from ATI.
Sapphire paper manual is useless and the Driver CD PDF manual doesn't even apply to the HD 5870 but only HD 4890 or lower cards.
Searching ATI support comes up zero results. Eyefinity searches on Google just provide ATI intro news.
Can someone plz give a how to for Eyefinity set-up? There is absolutely nothing anywhere for Zero Day HD 5870 owners
Alright figured it out. I had by habit immediately extended my desktop using the multi-monitor setting but that is where I messed up.
CCC Help menu for Eyefinity if you select Help Contents you will find it.
About ATI Eyefinity Technology and Display Groups
"To configure properties for specific displays in a group, use the display-specific property pages that are accessible through the display palette. For more information, see Configuring Display Properties."
Go on to Configuring Display Properties and it will guide you along.
Ok ATI you need an "EyeFinity" tab to make this more intuitive!
Thanks for your encouragement :)
message the amd rep on the forum
