Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to TechPowerUp Forums, Guest! Please check out our forum guidelines for info related to our community.
The forums have been upgraded with support for dark mode. By default it will follow the setting on your system/browser. You may override it by scrolling to the end of the page and clicking the gears icon.
Do I have to uninstall or disable Catalyst Control Ceneter in order to use ATI Tool. I would like to run them at the same time so that I can use AVIVO Converter.
Thanks
Thanks
No you do not have to, you can simply disable Catalyst AI when you dont want it, it is under the 3D section in the side menu, just put a cross in the box so 2 speak, click apply and it will stay that way until you want to use it, it should then be set as "disabled in ATI tool, look under "settings" then at the top drop down menu go to "driver tweaks" and check Catalyst AI level is set to "off".
