Hi all, I am just a new user and new to those high end graphic cards.
I have a few questions and things to say but i don't know how to create a new one.
1) Ati Tool works well (version 0.0.22) on my Powercolor 9600Pro 256MB 128Bit but only up to 450/220.
2) A gold star for the Tool developer(s) and can i ask that:
2a) Are you 1 of the Ati driver developers?
2b) What program language you use to write this tool?
3) Am I right that the clock lock is a bit mask -> in software rather hardware (Ati 9600 or R350 chip)
4) Does Powercolor 9600Pro 256MB have Temperature Monitor?
5) What is the max. clocks that some1 can set? Mine is 450/220 without any Atifacts.
6) Is it worth to get 9800Pro 128MB compare to 9600Pro which it would cost 30-40% more than 9600Pro)?
7) Faster clock speed, warmer component.
7a) 9600XT has a max clock speed of 500/300 and it's the same chip as my 9600Pro. So i overclock my 9600Pro to that 500/300 but why the GPU reset and did not work if i set to that level?
7b) Some1 said the card will have a shorten life time. Why is that?? since the chip is designed to run at 500/300. And also i see the 9600XT but different brand name, and they have a smaller fan than mine (if heat release is the thing caused that short life?)
Thanks
Thanks
