ATI Tool Problem
Clutch442
26 (0.00/day)
Woodhaven, New York
System Name Carpeter442
Processor AMD 5000+ BE @3210
Motherboard MSI K9A2 Platinum
Cooling AC Freezer 64 Pro
Memory 2 GB OZC PC 6400
Video Card(s) Visiontek HD 3870 OC Edition Sapphire HD 3870 "Toxic" Crossfire
Storage WD 320 GB / Hitachi 250 GB
Display(s) View Sonic 19" P95fx CRT
Case Antec SX 835
Power Supply Antec Earthwatts 500 + Thermaltake 450W Power Express
Benchmark Scores 3D Mark 06 12342 (so far)
Hello, Whenever I try to "find max core-find max memory-scan for artifacts-show 3Dview"
I get this.
Everything seems to work right on my Visiontek 3870, anybody know how to get by this?
Also I don't see where to change the voltages.
Thanks; Clutch
What version of ati tool are you using? You might wanna try 0.27 beta4 ?
Thanks for the reply, I have 0.26, I'll try the 0.27 beta version and see what happens.
Great 0.27 works, now I just need to know if you can increase GPU voltage with this tool.
I remember reading in Toms Hardware he bumped the voltage with ATI Tray tools.
So I guess that means you can only raise the voltage with the pencil mod?
I heared from sneekypeet that you can rise the voltage with a bios mod
Tom seems to have found a way to do it with ATI tool tray. I can't figure out how he got to the screen on the right. The screen on the left is mine.
Anybody know what he did? He gives no explaination. (That's from Toms Hardware)
