Automatic Fan Controller
457 (0.07/day)
Irvine, CA
System Name My3yrOldBaby
Processor Intel C2Q Q6600 G0 2.4GHz (3.6 Ghz @ 1.400V)
Motherboard eVGA 790 FTW (Analogue) 132-YW-E179-A1
Cooling Thermalright Ultra-120 eXtreme (Push+Pull: Silverstone 120mm)
Memory 8GB G.Skill DDR3 2x4GB 1866 (running 1600) + 2GB Crucial Ballistix DDR3 1x2GB 1333 (running 1600)
Video Card(s) eVGA 8800GTX 768MB
Storage (2) WD Raptor 150GB SATA [RAID 0], (4) Seagate Barracuda 320GB SATA [RAID 0+1]
Display(s) Acer 20" - AL2017, Acer 22"W - AL2216WBD
Case Thermaltake Armor w/ 25cm Fan & Extra Front iCage
Audio Device(s) OnBoard
Power Supply Silverstone 1000W - ST1000
Software Windows XP Pro x64
Hey Guys,
My new build has around 12 or more fans in it (Case, Ultra120x, NB/SB/VGA, SlotCooler, etc.) SO, I'm thinking a fan controller may be well in order. I would like an Automatic one so that it adjusts them based on the temperature (I know the mobo connectors do this automatically if you set them up so, correct? So, I could Daisy-Chain a bunch together using Y-Splitters or something, but I would prefer to use an overall controller).
Anyone know of a good Automatic Fan Controller for lots of fans?
Mediocre
1,237 (0.18/day)
Processor C2D E8400 @ 3.60GHz
Motherboard ASUS P5Q-Pro w/ extra Vreg HS
Cooling Apogee GTX, 2x120mm DD, MCP-1000P Res/Pump, all 3/8" 7x80mm (4x push/pull, 2x exhaust, 1x side)
Memory 2 x 1GB Corsair Dominator DDR2 1066 @ 800 (4-3-3-6)
Video Card(s) EVGA 9800GTX+
Storage 3 x 80 GB WD SATA300 (2x RAID 0)
Display(s) Scepter x37 1080p 37" LCD & Samsung 204B
Case CoolerMaster HAF932
Power Supply Mushkin HP-580AP (C/O TPU!)
Software Vista Ultimate (32-bit)
always check the current draw on your fans and compare with your motherboards max for each header. It was 500mA (0.5A)for my board. The current draw is usually on the sticker. Its usually in the neighborhood of .1-.3
You can usually take 2 fans and cut the ends off and tie them togther into one plug and its ok. To go with more I woul make sure you're 10% lower than the max rating. If its rated in watts, multiply the current by 12 to get watts (100mA = 0.1Amps)
You could also just tie them all to 7V instead of 12V. They are much quiter then. Move the wire connected to ground (black) and plug it into a 5V (red) line. This changes your ground reference from 0 to 5 volts. So 12 - 5 = 7V. I ran my side intake fan like that before the 2900 because it would rattle.
Oh and check www.frozencpu.com for good fan controller ideas. You may need one with that many fans :p
:toast:
Random Murderer
The Anti-Midas
6,974 (1.04/day)
Florida, A.K.A. the Sweatbox
System Name TOO MUCH RADIATOR! | The TV Box a.k.a. The Shoebox
Processor Core i7 4930K @ 4.5GHz | Core i5 6600K @ 4.5GHz
Motherboard Asus X79 Rampage IV Extreme | Asus Z170i Pro Gaming
Cooling Custom water on CPU and GPU, dual 360mm radiators | Corsair H80i
Memory 4x 8GB G.Skill TridentX DDR3-1600 | 2x 4GB G.Skill RipJaws 4 DDR4-3000
Video Card(s) Sapphire AMD R9 295x2 | PowerColor AMD HD7970
Storage Samsung SSD 830 256GB, various others | 2x 1TB Seagate Barracudas in RAID1
Display(s) Dell U2713HM 2560x1440 IPS | Panasonic TC-L32E5 1080p IPS TV
Case Thermaltake Suppressor F51 (stripped down to hold two radiators) | Cooler Master Elite 130
Audio Device(s) RM-DAC -> Xiang Sheng 708b -> Sennheiser HD650 | HDMI sound device on 7970
Power Supply LEPA G1600-MA 1600W | Corsair CX750M 750W
Software Win 10 64
Benchmark Scores over 9000 BungholioMarks, "Bitchin' Fast"
457 (0.07/day)
Irvine, CA
But then that makes them instantly slower. I always see people giving these options on how to make their fans automatically quieter, like putting them in parallel, decreasing the input voltage... the only way a fan can be quieter is if it slows down, which is not necessarily what I want all the time. I only want it slow when it needs to be, but when I'm at full load @ a high OC, then I might very well need the full speed.
Thus comes in the Fan Controller.
I might use your idea of tying the wires together tho instead of getting a bunch of y-splitters. We'll see.
457 (0.07/day)
Irvine, CA
Sweet thanks Random_Murderer. I'll check those controllers out.
179 (0.03/day)
System Name My last amd rig for now i love my new i7
Processor Amd fx-9590
Motherboard ASROCK Fatal1ty 990fx pro
Cooling liquid
Memory G. Skill Ripjaw ddr3 1600 x32gb
Video Card(s) Dual AMD XFX 7990
Storage Samsung 840 pro
Display(s) asus
Case Dell 1520 c2d@2.6 4gb ddr2 667 8600m gt 500gb 7200rpm hitachi
Audio Device(s) Asus ROG g60J I7@2.8 8gb ddr3
Power Supply Antec 1200w
Software windows 7 x64
457 (0.07/day)
Irvine, CA
That PCI slot card looks way dope... exactly what I'm wanting to do with it, however...
I was really hoping for a 3.5" floppy-size controller that did this, so that I could fit it into the power-button 5.25" slot's bay on my Thermaltake Armor, which would look dope. But, this is looking more and more infeasible. So, I'll probably just get a 3.5" manual controller.
I feel like it wouldn't be that difficult to have an internal USB connected 3.5" LED Display fan controller that could handle like 6 fans, and then connects like a permanent USB to your system, and it would have a software fan configuration program. Basically that sunbeam thing, but 3.5" w/ LED display. Would maybe be like $35, but it would be SO worth that.
That Sunbeam Theta would definitely be the way to go tho right now, good piece of tech right there.
