automatic shutdown
regan1985
1,449 (0.21/day)
Coventry UNI England
Processor yorkfield core 2 quad Q8200 3.2ghz 1.26v
Motherboard asus p5Q SE
Cooling akasa ak965
Memory Kingston 1066 2x2gb 1104mhz 2.2v
Video Card(s) SAPPHIRE HD 2600 XT DDR3 857/1078
Storage 2X Samsung spinpoint 500GB 7200 4x 1tb samsung eco 5400
Display(s) 2xSamsung P2270 22" Widescreen
Case NZXT Hush Quiet Case in Black
Power Supply OCZ StealthXStream 500w Silent Power Supply
Software windows 7 64
ello!!!
ive been worried about my heatsink ive just fitted,as in it didnt fit as good as i hoped its a thermaltake blue orb2 its pritty big!! cools the cpu much better then before but im woried it may more all fall over lol!!!
is there a setting in my bios or a program i can get that turns the pc off wen the temp gets to high??????
u can see my pc spec!!!
with a blue orb the temps wont be too high anyways... did u put the hsf on tightly? if u did, theres no need
Your processor is likely to turn itself off if it gets too hot I think. As long as your new cooling can withstand you knocking it around a little bit when it's off, I expect it will be fine.
its tight but for some reason wen my computer is upright it must move a bit, its dont its twise and temps have gone from 32 to 55 and then up then it turns itself off i hope! i just wated a safe gaurd just incase it doesnt turn itself off
