Average Operating CPU Core Temp
rikitheshadow
2 (0.00/day)
K, I've got questions for anyone who is experienced with heat syncs and thermal paste. Just got finished building a computer on my own for the first time, no experience with applying and ensuring that the CPU will be safe. I'm running a Intel Core 2 Duo 2.66 GHz on a Abit IP35 Pro (MB) with a 650 watt power supply, and the with an ATX 12v 8 pin to the CPU. There are pleny of case fans keeping the case temp to an average of less than 25 - 30c(celsius). The motherboard does have a safety feature to shut off the power if any of the 2 (cpu core and case temp) exceed a set temperature, but i'm just a little nervous cause it was my first time to apply a heat sync to a CPU (w/ thermal paste). Took me 2 trys to get the heat sync properly attached and i was afraid that would mess up the thermal paste. So far I have windows running and everything so I assume if i had enough time to get an OS and format the HD that the thermal paste and heat sync are working properly. Idle temp of the cpu core is 29-30c and for example if I have a program like MAME(Multiple Arcade Machine Emulator) running its 50-55c. Does the idle and operating temp of the CPU core seem nominal or correct for the type of processor i'm running?
Btw i'm only addressing this thread for cooling issues, I don't intend to overclock my computer which may risk my hardware warranty.
If you are using the stock cooler as supplied with the CPU, your temperatures look about right (assuming your temperature reading is correct).
You are at about normal... there is nothing wrong with those temps...
your temps look fine, i wouldnt worry but....
if you hang out here for a while you may just decide to overclock it a bit. the chance of breaking anything is very small. just hang around a bit and do some research. when/if the time comes and you need any help just ask.
and also Welcome to TPU
