Backplate Cooler For Intel Socket 775
646 (0.11/day)
South East, United Kingdom
System Name Swag
Processor Intel Xeon E3110 4GHz
Motherboard GIGABYTE GA-G31M-ES2L
Cooling Scythe Infinity I Push-Pull w/ AS5
Memory 2x2GB Transcend 800MHz DDR2 @ 890MHz 1.9v
Video Card(s) Palit nVIDIA GTX460 1GB 800/1600/2000
Storage Crucial M4 64GB
Display(s) LG Flatron M1917TM 1280x1024 @ 60Hz
Power Supply OCZ StealthXStream 2 600W
Software Windows 7 Professional 64-bit
Can someone recommend a cooler with a backplate for socket 775, as I really hate push pin shitty coolers cos my motherboard is such a tight squeeze I can never get them to fit properly...
I like the look and reviews of the Xigmatek HDT-S1283 but it doesn't have a backplate, is there anything similar around the £20-25 mark with similar performance with a backplate?
Thanksss (:
You usually get the back plate separate. If you are going with a heat sink from Xigmatek I would suggest that you get a backplate from them as well.
So you can consider the Xigmatek Crossbow
Are just a few places I've found but I'm not sure what's available in your area.
