- May 24, 2023
- 1,204 (1.65/day)
System Name | The Dark side of the room |
Processor | AMD Ryzen 9 5900X |
Motherboard | MSI MEG X570 Unify |
Cooling | Custom loop watercooling (Bykski CPU-XPR-POM-M-V2, Alphacool Eisblock GPX, Freezemod PU-PWM5B18W) |
Memory | GSkill Ripjaws V DDR4 3600 CL16 (4 x 16GB) |
Video Card(s) | XFX Speedster QICK 319 Radeon RX 6700 XT |
Storage | 1 x Kingston KC3000 1024GB (boot drive) + 2 x Kingston NV2 2TB (games & storage) |
Display(s) | LG 34WP65C Ultrawide 3440x1440 @ 160Hz freesync premium |
Case | Thermaltake Core P90 TG (slightly modded) |
Audio Device(s) | onboard Realtek® ALC1220 with Logitech Z906 |
Power Supply | MSI MAG A850GF 80 Plus Gold |
Mouse | Roccat Burst Pro black |
Keyboard | Sharkoon Skiller SGK60 (with brown Kalih switches) |
Software | Windows 11 pro |
Benchmark Scores | It's a form of exhibitionism...;-), but fun in a way But showing off is triggering............. |
As far as I know, most waterblocks (CPU & GPU) have an optimum efficiency with approximately 100 ~ 120 l/h coolant flow.
In series, you just have to pump 100 ~120 l/h around for both blocks, parallel you have to give each block 100 l/h so you have to pump 200 ~240 l/h around to have a comparable efficiency.
I have a solid metal door and I do not need to see the (ugly) pink hose spaghetti.But if you like the aestetics of a parallel loop, nobody is stopping you. Instead of a valve you can also use a orifice or an inline filter to create the needed flow restriction on the CPU block.
